#41 |
Zeke3 may be on to sumpthin, I know the earlier ford solenoids will stick when mounted upside down. It seems they need gravity to help the spring unload the connection
#42 |
When I correct the solenoid do I need to do anything with the wires or just rotate it 180 and put it back on?
#43 |
Sorry I'm ate to the party, But welcome and that is way too nice of a truck to go into yard art jail. As to you last question no , you can just disconect the wires turn the noid over and reatatch the wres to the new terminal that's now on that side. Again welcome. Tim
#44 | |
![]() Quote:
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
#45 | |
![]() Quote:
#46 |
Brendan
#47 |
The gauges are not hooked up or partially hooked up. I will take a picture when I get home. The ignition switch is like you describe but does not snap back when released like a modern car.
#48 |
There was a time that I turned the key off and the starter was still running.
#49 |
what i see is you have a modren type starter solenoid. its up side down, after you turn it right side up the big termanl on the right goes to the battery, the big one on the left goes to the starter motor. the little termanl on the left goes to the start termanel on your ignition switch.when you are in the start position the switch will feed 12 volts to engeize the solenoid. it sounds like the wireing between the switch and solenoid is mest up. after you turn the solenoid around . disconect the little wire on the left, and use a screw driver to jump the battery
side of the solenoid termanl , the starter will operate , and after you disconect ,it will stop i hope this is not to much Brendan
#50 |
Thats a Kool Truck, when i was a kid my Dad had a 51 F1 i sure learned alot with that truck
#51 |
https://images.search.yahoo.com/sear...g&action=click
hope this helps its a Ford wireing diagram for the starting circut Brendan
#52 | |
![]() Quote:
#53 | |
![]() Quote:
#54 |
i think if your truck is a 49 the battery is on the driver side, don't be sorry for lack of knowlege. its all learning experiences we all have to learne sometime, wireing is very confusing for some people , Just keep the smoke in the wires...LOL
#55 | |
![]() Quote:
Alan |
#56 |
![]() ![]() I flipped the starter solenoid and cleaned all the connections. I will attempt to start it today. |
#57 |
Kool , let us know anout the results!
#58 |
Kind of bummed. It did the same thing. Cranked sounded like it tried to turn over but everything stopped and left the starter engaged and running.
#59 | |
![]() Quote:
Glenn
Archives of historical but relevant older articles: ------------- Hover mouse over the links below and click! ~~~~~~~~~~~~~~~~~--------------- Rumble Seat's Notes Techno-Source-for-the-1932-thru-1953-Flathead-Ford |
#60 |
Thanks Glenn. Recommendations on a battery? Optima Red Top?
