#41 |
I would agree, but it is a possibility if someone is interested.
#42 |
The rods are the same for the ford an merc. only the pistons are different to make up for the 1/4 inch difference in stroke.
#43 |
Believe everyone understands that, the other option is the French rods which are shorter.
#44 |
keep in mind if the bore goes over 60, merc piston options get scarce
#45 |
Cas3
I don't understand?? Perhaps you're thinking about stock overbore stuff? 20, 30, 40, etc? Egge will make 3 5/16 + .015 or .020, or .030 Ross will make almost anything, with almost any ring config Jim |
#46 |
![]() On Ol'Ron's recommendation I went out to Long Island to visit Gary (GOSFAST) at The Engine Shop. What a great guy who clearly knows his flatheads. I'm looking forward to learning the condition of my block and hopefully getting the build started. I'll be back with updates ![]() ~ Carl |
#47 |
Good luck and have some fun!
B&S |
#48 |
Good choice. You seem to be in the right location. I wish he was closer to me.
#49 |
Finally, someone took my advice. You won't be sorry.
#50 |
Ron, you always knew it would happen someday!
#51 |
