Old 06-29-2017, 07:31 PM   #41
JSeery
JSeery's Avatar
Default Re: 8BA rebuild - do I want a Merc crank
I would agree, but it is a possibility if someone is interested.
Old 06-29-2017, 07:56 PM   #42
oldfordman33
The rods are the same for the ford an merc. only the pistons are different to make up for the 1/4 inch difference in stroke.
oldfordman33 is offline   Reply With Quote
Old 06-29-2017, 08:10 PM   #43
JSeery
JSeery's Avatar
Believe everyone understands that, the other option is the French rods which are shorter.
Old 06-29-2017, 09:42 PM   #44
cas3
keep in mind if the bore goes over 60, merc piston options get scarce
Old 06-29-2017, 11:36 PM   #45
Kahuna
Kahuna's Avatar
Cas3
I don't understand??
Perhaps you're thinking about stock overbore stuff? 20, 30, 40, etc?
Egge will make 3 5/16 + .015 or .020, or .030
Ross will make almost anything, with almost any ring config
Jim
Kahuna is offline   Reply With Quote
Old 07-10-2017, 10:29 AM   #46
cederholm
cederholm's Avatar
Worried that you guys are losing sleep over this thread, I'm back with an update!
On Ol'Ron's recommendation I went out to Long Island to visit Gary (GOSFAST) at The Engine Shop. What a great guy who clearly knows his flatheads. I'm looking forward to learning the condition of my block and hopefully getting the build started.
I'll be back with updates
~ Carl
cederholm is offline   Reply With Quote
Old 07-10-2017, 07:59 PM   #47
Bored&Stroked
Bored&Stroked's Avatar
Good luck and have some fun!
B&S
Old 07-10-2017, 08:14 PM   #48
tubman
tubman's Avatar
Good choice. You seem to be in the right location. I wish he was closer to me.
Old 07-10-2017, 09:28 PM   #49
Ol' Ron
Ol' Ron's Avatar
Finally, someone took my advice. You won't be sorry.
Old 07-10-2017, 10:38 PM   #50
JSeery
JSeery's Avatar
Ron, you always knew it would happen someday!
Old 07-11-2017, 07:09 AM   #51
cederholm
cederholm's Avatar
Thanks again Ron. I'm sure that his craftsmanship is top notch, but I also really appreciate his taking the time to educate me as I plan to assemble the motor myself and have a lot to learn
