Old 10-03-2012, 10:08 AM   #21
Old Henry
Old Henry's Avatar
Default Re: Vinegar
Originally Posted by mrmoose View Post
Henry, just when everyone was having a good discussion, you had to go and get sensible on us!
This discussion always reminds me of one about, "Which is better to brush you teeth with? Salt or baking soda?"
Duh. Ever heard of toothpaste?
Old 10-03-2012, 11:16 AM   #22
Zeke...PA
Zeke...PA's Avatar
Default Re: Vinegar
Maytag at one time had a product to clean rust from their washing machines, it's ingredients were citric acid crystals that can be bought at a drug store, it did work well. It is called Rover, can be bought on ebay for about $5.00. Zeke
Only problem with retirement is never a day off
Zeke...PA is offline   Reply With Quote
Old 10-03-2012, 12:18 PM   #23
FL&WVMIKE
FL&WVMIKE's Avatar
Default Re: Vinegar
Originally Posted by Old Henry View Post
Here's what I have used on many cooling systems that is not acid and is specifically made for cleaning cooling systems:
Read more about it here: http://www.prestone.com/products/print/379?popup=1
Just did mine before my recent Rocky Mountain High Road trip (https://www.fordbarn.com/forum/showthread.php?t=83966) followed by back flushing as demonstrated here: https://www.fordbarn.com/forum/showthread.php?t=83557. Cleaned it up good.
Old Henry ....................
Remember when you used to be able to buy small cans of radiator cleaner, just about everywhere ? The EPA has put so many restrictions on these cleaners, that they are almost useless, now days. Maybe, two gallons of the new stuff has enough cleaning solutions in it to do the job.
That is why, people have been going to alternative methods to clean their radiators.
If you have your parts off, a power washer is great for rinsing.
MIKE
FL&WVMIKE is offline   Reply With Quote
Old 10-03-2012, 12:38 PM   #24
Cecil/WV
Cecil/WV's Avatar
Default Re: Vinegar
Vinegar is safe and good enough for me.
Cecil/WV is offline   Reply With Quote
Old 10-03-2012, 02:16 PM   #25
peewee2you
peewee2you's Avatar
Default Re: Vinegar
Walt, on American Restoration - it listed three items for removing rust stains?
Cider Vinegar, Lemon Juice, Tea? I think that was the last one, memory? Anyways
Cider Vinegar was the best out of all of them to use.
peewee2you is offline   Reply With Quote
Old 10-03-2012, 03:43 PM   #26
1937pickup
Default Re: Vinegar
There is a scale for acidity and alkalinity. If I remember right 5.5 is neutral where life will exist. Less than 5.5 is acid-greater than 5.5 is alkiline you neutrilize acid with alkiline (base). Have you ever put baking soda on battery terrmanals to clean them? That was neutralizing the batery acid with a base. The scale is not arithmatic it is logrymic.
1937pickup is offline   Reply With Quote
Old 10-03-2012, 06:41 PM   #27
trainguy
trainguy's Avatar
Default Re: Vinegar
Be careful with muratic acid year ago i used it to clean out a 1912 Oakland radiator.I left it in over nite and it ate the solder out of the rad.I had to have a new core made,BIG BUCKS.Phil
trainguy is offline   Reply With Quote
Old 10-03-2012, 10:21 PM   #28
Wily Kyote
Wily Kyote's Avatar
Default Re: Vinegar
[QUOTE=Old Henry... Here's what I have used on many cooling systems that is not acid and is specifically made for cleaning cooling systems...]
In my opinion, this reasoning fits the physcian's code... "first do no harm". If I had applied that test to my (hobby) car work for a half-century, I would have happier memories today. (And less ruined old Ford pieces. Ouch! The failures still pain me.)
If there is a hereafter, too many flatheads await me, hands in hips, a look of disgust or pain in their eyes. Maybe I'll just skip that and go below, where flatheads do not exist.
Wily Kyote is offline   Reply With Quote
Old 10-03-2012, 11:39 PM   #29
IVT1
IVT1's Avatar
Default Re: Vinegar
I was sitting on the back porch drinking a vinegaraid & it hit me,what would lemonaid taste like ( whoa maybe I'm on to something
Go hard, or Go home
IVT1 is offline   Reply With Quote
Old 10-04-2012, 06:37 AM   #30
Old Henry
Old Henry's Avatar
Default Re: Vinegar
[QUOTE=Wily Kyote;510763
In my opinion, this reasoning fits the physcian's code... "first do no harm". [/QUOTE]
And, "If it ain't broke, don't fix it!"
Old 10-04-2012, 07:48 AM   #31
trulyvintage
trulyvintage's Avatar
Lightbulb Taco Salad ?
Originally Posted by CBoz View Post
Just a side thought: If I filled my radiator with vinegar and it leaks onto my lawn, along with the slight amount of oil coming through the cotter pin hole on the back of my oil pan, would that constitute making a salad?
Yes ...
But if you add a 'contribution ' made by a Chihuahua
and add some tortilla chips ....
Taco Salad ....
Jim
trulyvintage is offline   Reply With Quote
