Old 07-09-2011, 08:02 PM   #21
glenn in camino
glenn in camino's Avatar
Default Re: Adding 600w oil to the steering box
Why do think Ford put a grease fitting on the 7 tooth box if you're not supposed to use grease. I mix 600W with chassis grease until it barely flows. I works great and doesn't leak out.
glenn in camino is offline   Reply With Quote
Old 07-10-2011, 01:19 AM   #22
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Venting?
Old 07-10-2011, 05:08 AM   #23
Patrick L.
Patrick L.'s Avatar
The heavy weight oil was loaded in grease guns back then..
Old 07-10-2011, 02:56 PM   #24
Christoph
Christoph's Avatar
Mr. Tube :
As my fingers are allways dirty;
I guess oil should clean my fingers too
My wife would kill me, so i tryed writing (im not good in writing)
Christoph
Christoph is offline   Reply With Quote
Old 07-10-2011, 04:03 PM   #25
Fred K-OR
Fred K-OR's Avatar
Originally Posted by Larry Seemann View Post
Your fill plug may look like a large Alamite grease fitting. A lot of them were like that and a lot of people filled them with grease (BIG MISTAKE!) because of the grease fitting plug.
Larry, is this what you ment by Alamite grease fitting or are you just referring to a "normal" grease fitting? This thing caught me by supprise when I bought the car a few months ago. I think I may have messed up by filling it with grease.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 07-10-2011, 06:40 PM   #26
1931 flamingo
1931 flamingo's Avatar
YUP
Paul in CT
Old 07-11-2011, 02:58 AM   #27
ryan1929
ryan1929's Avatar
Hey What can happen if oil from the steering box and light switch mix? For some reason my cowl lights have not worked since last fall...Could this be the problem?
ryan1929 is offline   Reply With Quote
Old 07-11-2011, 04:46 AM   #28
Mike V. Florida
Originally Posted by Franchise_24 View Post
Ok, I found it. Thanks to everyone for their responses. I'm going on a club meet tomorrow so I will not have time to mess with it tonight. Incidently someone mentioned that it could leak out by the lightswitch inside the car. What is that all about? Definately wouldn't want that to happen!!
This is for the 7 tooth
This is for the 2 tooth
