Old 07-08-2011, 11:00 PM   #15
Franchise_24
Franchise_24's Avatar
Default Re: Adding 600w oil to the steering box
Originally Posted by Patrick L. View Post
Franchise, yes you do open the drivers side of the hood and just follow the steering column..
At the end of the column is the steering box and you'll see a plug or grease fitting on the top of the box.. You have to unscrew the plug or fitting and pour in the oil.. It only holds a couple ounces, but, fill it up anyway.. It'll leak out but won't hurt anything..
Ok, I found it. Thanks to everyone for their responses. I'm going on a club meet tomorrow so I will not have time to mess with it tonight. Incidently someone mentioned that it could leak out by the lightswitch inside the car. What is that all about? Definately wouldn't want that to happen!!
Franchise_24 is offline   Reply With Quote
