Old 04-26-2011, 08:02 PM   #21
Cider Mill
Cider Mill's Avatar
Default Re: AA transmission Q
By regular, I mean one without the PTO for a hydraulic dump. Mine has 2 extra levers that operate a small PTO shaft that runs back to the hydraulic pump. I'd like a 4 speed tranny with out the PTO option.
Cider Mill is offline   Reply With Quote
Old 04-26-2011, 08:06 PM   #22
modeleh
modeleh's Avatar
You can just unbolt the PTO from the trans and make a cover plate and gasket to cover the opening.
modeleh is offline   Reply With Quote
Old 04-27-2011, 08:12 AM   #23
sturgis 39
I think the covers for the pto are the same on most old transmissions. The covers are usually made out of sheets metal. Some of the auxiliary transmissions had a PTO cover according to a post on this forum. After the snow melted, I checked mine and there were no PTO covers on my axillary transmission..
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED
Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread.
sturgis 39 is offline   Reply With Quote
Old 04-27-2011, 08:20 AM   #24
Rowdy
Correct, they were the same covers for the PTO from 29-47, maybe until 52, but I can not say for sure on that. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 02-24-2012, 07:55 PM   #25
29Doodlebug
I know this a old post, but in my seach for a AA U-joint, I can't find one that will fit my 4 speed trans. And I think Rowdy U-joint is the one I need. I was hopeing Rowdy still had his U-Joint or something like it? Mine is a 6 spline but bigger than a model A U-joint
Let me Know
Thanks
Kyle
29Doodlebug is offline   Reply With Quote
Old 02-24-2012, 09:05 PM   #26
Tom Wesenberg
Tom Wesenberg's Avatar
If Rowdy doesn't have one try Little Dearborn in Minneapolis. 612-331-2066
Old 02-24-2012, 09:55 PM   #27
columbiA
The PTO cover plates are a std SAE plate used from around 29 right up to the 80,s or even later on 4 & 5 spd truck trans.
columbiA is offline   Reply With Quote
Old 02-24-2012, 10:29 PM   #28
columbiA
The AA,s didnt use a U-joint at the trans end of coupling shaft.Instead,there was an internal-external wide tooth coupling that allowed a couple degrees angular movement to allow for frame flexing.The rear end of C-shaft mounted to cross member & had U-joint for rear end.There may have been 2 sizes of U-joint as the later 31 LWB AA,s used a larger size coupling shaft.
Old 02-24-2012, 11:17 PM   #29
Bob C
ColumbiA, there was a service replacement coupling shaft that came out in
1932 that used a bolt together u-joint so you could remove the coupling shaft
without removing the rear end or engine.
Bob
File Type: jpeg ford_service_bulletin__july_32__page_35x_120.jpeg (26.5 KB, 19 views)
Old 02-25-2012, 01:56 AM   #30
columbiA
Bob C . I learned something new! I didnt know about the improved retro fit C-shaft that came out in 32. I have a 4-speed with the special rear brg retainer & U-joint so that the trans would fit the A chassis.
Old 02-25-2012, 05:29 AM   #31
Rowdy
I have 4 or 5 of the truck u-joints and some for parts. Give me a call Sunday evening and I will make sure I have most of them close by so we can figure out which one you need. Thanks Rod 308-529-2467
