Old 02-01-2025, 03:59 PM   #21
GB SISSON
GB SISSON's Avatar
Default Re: Hello New to Forum
Welcome to 'The Barn'. I like your truck too. Pretty rare find in that condition in the Northeast! What about running boards? Couple of times I have used fiberglass ones and brush painted them with rustoleum rusty metal primer. I have received comments about my nice straight running boards from knowledgeable enthusiasts. Nobody would even dream that a guy would load brush paint onto fiberglass reproduction parts, so it never comes up. Or maybe you have your metal ones but haven't installed them yet. Keep up the good work.
Old 02-01-2025, 04:49 PM   #22
tubman
tubman's Avatar
Sounds like you need a new Bendix drive on your starter.
Old 02-01-2025, 05:55 PM   #23
signsup
I'm no mechanic, but starter spinning but engine not turning over sounds like starter bendix or spring to me.
signsup is offline   Reply With Quote
Old 02-01-2025, 07:00 PM   #24
foamspoon
I first had to find running board brackets, then I had the priveldge of removing the rivets of the old brackets.
I bought steel reproduction running boards. I still have to weld the supports on the bottom. I also replaced the old tailgate. Old tailgate was pretty shot with a new reproduction one.
foamspoon is offline   Reply With Quote
Old 02-01-2025, 07:04 PM   #25
foamspoon
Sorry pictures so big.
Old 02-01-2025, 07:43 PM   #26
highbeams
highbeams's Avatar
Welcome to this Friendly Place!
highbeams is offline   Reply With Quote
Old 02-01-2025, 11:09 PM   #27
cas3
Thats a wood rimed, block chain bicycle hangin up in the back there, about 1900, what else are you hiding from us buster?
Old 02-02-2025, 12:53 AM   #28
GB SISSON
GB SISSON's Avatar
I too have stolen running board brackets from parts trucks. Chisel off both sides heads on the rivet and the bracket is just as connected as before. Driving it out seems to swell the rivet's shank instead, making it tighter yet. Center-punch and drill, but in 1974 who had a cordless drill out in that field? Beat, bash, twist and shout! When you get those gnarled brackets home is when you learn how to straighten steel. Good thing they're hidden under there. I like your new running boards and tailgate. That good ol survivor deserves them.
Old 02-02-2025, 03:38 AM   #29
foamspoon
It is my father's from when he was a kid. My brother left outside for years and trashed it. I "liberated" from his yard one Christmas and brought it home.
Old 02-02-2025, 05:13 PM   #30
foamspoon
I cranked everything moving, it seems to start but everything stops and you hear the starter continuously run in background.
Here is the part I forgot to add, if it helps, after 10 seconds of the starter running the engine flipped back to cracking the like the start of the video.
Old 02-02-2025, 05:14 PM   #31
foamspoon
I will post the youtube video of the failed attempted start up. you can hear the starter in the background.
Old 02-02-2025, 05:14 PM   #32
foamspoon
https://youtube.com/shorts/9h6NJdG1JzM
Old 02-02-2025, 05:18 PM   #33
foamspoon
[yt]https://youtube.com/shorts/9h6NJdG1JzM?si=sMdNHSxbICoPceY1[/yt]
Old 02-02-2025, 05:22 PM   #34
Ggmac
It seems the motor started and when stalled the starter was still running ?
Does it have a new looking starter button ? Recheck solenoid wiring . Possibly if the wiring is correct the solenoid is sticking . Sticking solenoid is my primary.
Ggmac is offline   Reply With Quote
Old 02-02-2025, 05:22 PM   #35
Ggmac
Take a pic of your solenoid and wiring . Is it still positive ground ?
Old 02-02-2025, 05:24 PM   #36
foamspoon
photos
File Type: jpg Screenshot 2025-02-02 at 4.49.19 PM.jpg (20.8 KB, 23 views)
File Type: jpg Screenshot 2025-02-02 at 4.49.04 PM.jpg (11.4 KB, 20 views)
Old 02-02-2025, 05:26 PM   #37
foamspoon
Old 02-02-2025, 05:42 PM   #38
Bob C
My guess is the solenoid is wired wrong. There are nine different solenoids so you need to identify which one you have.
Old 02-02-2025, 08:14 PM   #39
Zeke3
Zeke3's Avatar
The solenoid looks upside down to me, I don’t recall seeing one mounted like that before.
Zeke3 is offline   Reply With Quote
Old 02-02-2025, 08:20 PM   #40
Model A Canuck
Model A Canuck's Avatar
Welcome to the Barn
Model A Canuck is offline   Reply With Quote
