#21 | |
![]() Quote:
1928 Roadster Pickup 1930 Tudor 1943 Ford WWII Jeep 1968 Taco Minibike Member, Santa Anita Model A's Arcadia Ca. |
#22 |
Put a strong magnet onto the flywheel, and turn the engine over slowly by hand. as the magnet goes around you should hear the magnet pick up the bolt and one the magnet get to the starter opening remove both of them.
#23 |
With the starter removed, place a strong "rare-earth" magnet on the outer diameter of the flywheel...rotate the engine using your hand crank and when the maginet re-appears so will your bolt
#24 |
Bob Biondi.
Thanks. That is what I am doing. Having my mechanic locate three OEM bendix bolts in the trans made the message clear. While they may be working well on some cars they have a serious flaw. I may not be a master mechanic but I am pretty sure that my predecessor and I did not install the bendix incorrectly three times. That lock washer is a pretty flimsy source of false security for something that can result in a catastrophic transmission failure. |
#25 | |
![]() Quote:
When you get the new replacement drive, extend the gear completely and compare the length of extension to the extension of an original Bendix drive. The original Bendix extends the gear 5/32 inch further which guarantees full engagement of the ring gear. The new drive is a tractor part that is not a direct replacement for the original Bendix. Total gear engagement also depends on the crankshaft thrust bearings and starter motor thrust. |
