Old 06-17-2024, 02:06 PM   #1
Tom F OHIO
Tom F OHIO's Avatar
Default Re: Is the bendix a nigtmare?
I lost a bolt off of my bendix and can't find it with a magnet. Will I be okay to
drive it with that bolt laying in there.
Tom F OHIO is offline   Reply With Quote
Old 06-18-2024, 12:15 AM   #2
German guy
German guy's Avatar
Tom OHIO,
Until it gets jammed in the flywheel.
German guy is offline   Reply With Quote
Old 06-18-2024, 03:23 PM   #3
Tom F OHIO
Tom F OHIO's Avatar
Yes that had me nervous. I went today and bought me a new flexible magnet and I got the bolt and the washer out.
Old 06-18-2024, 04:46 PM   #4
Dino's A
Dino's A's Avatar
Congrats Tom! Now you don't have to worry about that!
1928 Roadster Pickup
1930 Tudor
1943 Ford WWII Jeep
1968 Taco Minibike
Member, Santa Anita Model A's
Arcadia Ca.
Dino's A is offline   Reply With Quote
Old 06-18-2024, 08:57 AM   #5
Dino's A
Dino's A's Avatar
Hi Tom-I also tried a magnet but couldn't get it out. I took my shop Vac
and put a smaller hose in it and luckily, I got it out. The smaller hose I used
was about 3/4" ID. The size is a little critical because it has to be big
enough to grab the bolt but small enough to push the hose all the way down
to the area where it is. I have even heard of people putting magnets onto the
flywheel and hand cranking to get it. I choose the vacuum method as I didn't
want something like that falling off for some reason and causing more trouble.
If you play with it long enough, you'll probably get it.
Dino F.
1930 Tudor
1943 Ford WWII Jeep
1968 Taco Minibike
Arcadia Ca.
Old 06-19-2024, 07:56 AM   #6
jak
Put a strong magnet onto the flywheel, and turn the engine over slowly by hand. as the magnet goes around you should hear the magnet pick up the bolt and one the magnet get to the starter opening remove both of them.
jak is offline   Reply With Quote
Old 06-19-2024, 08:13 AM   #7
red or green
With the starter removed, place a strong "rare-earth" magnet on the outer diameter of the flywheel...rotate the engine using your hand crank and when the maginet re-appears so will your bolt
red or green is offline   Reply With Quote
