Old 04-11-2023, 11:33 PM   #21
whirnot
whirnot's Avatar
Default Re: Toe-End Gauge
Originally Posted by Phil Brown View Post
Toe plates can be simple wood or some bent aluminum plate to stand by themselves. Keep them pushed against the tire and throw a brick on them for some weight and measure away, hook tape on one side and read the other. Go high-tech with two tape measures ( one front and one back) and a helper to turn the tie rod while you read the tapes
The problem with that is it does not take into account a possible bent wheel.
I believe factory spec allowed up to 1/8 inch runout.
If you measure the same place on each tire, but move the car to the new location, it takes that out of the equation.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
1931 Coupe
2 Smith Motor Compressors
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 04-12-2023, 11:19 AM   #22
Phil Brown
Phil Brown's Avatar
If your wheels are bent it's going to mess up any tape measure toe-in setting
Phil Brown is offline   Reply With Quote
Old 04-12-2023, 11:59 AM   #23
30Murray
Find the most severely bent point on each wheel and make sure that is pointing either straight up or down and the toe plate method will work fine to give an average toe in measurement
30Murray is offline   Reply With Quote
Old 04-12-2023, 08:50 PM   #24
J Franklin
J Franklin's Avatar
Put the bent wheels on the rear.
