04-11-2023, 11:33 PM | #21 | |
Re: Toe-End Gauge
I believe factory spec allowed up to 1/8 inch runout. If you measure the same place on each tire, but move the car to the new location, it takes that out of the equation.
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
04-12-2023, 11:19 AM | #22 |
Re: Toe-End Gauge
If your wheels are bent it's going to mess up any tape measure toe-in setting
04-12-2023, 11:59 AM | #23 |
Re: Toe-End Gauge
Find the most severely bent point on each wheel and make sure that is pointing either straight up or down and the toe plate method will work fine to give an average toe in measurement
04-12-2023, 08:50 PM | #24 |
Re: Toe-End Gauge
Put the bent wheels on the rear.
