Old 10-29-2018, 07:19 PM   #21
JM 35 Sedan
JM 35 Sedan's Avatar
Default Re: Right Clutch Pressure Plate?
Link to Fort Wayne Clutch and Driveline website: https://fortwayneclutch.com/
John
Old 10-31-2018, 01:31 PM   #22
Nico73
Nico73's Avatar
What a Job, it takes me 3 hours to take the Clutch out of my truck ...
Nico73 is offline   Reply With Quote
Old 10-31-2018, 01:44 PM   #23
Nico73
Nico73's Avatar
New Clutch is allready ordered at Fort Wayne :-)
Thanks to all of you for the Support,
i really aprecciate it!
Old 11-01-2018, 11:41 AM   #24
Kahuna
Kahuna's Avatar
Very nice truck, Nico
Best
Jim
Kahuna is offline   Reply With Quote
Old 12-25-2018, 06:11 PM   #25
Nico73
Nico73's Avatar
At First, Merry Christmas to all of you.
I have one more question regarding my 9" clutchplate.
The Repair-Manual (Christmas Present) says, that the Trucks Always have pressure-plates with 9 Springs, instead of 6 Springs. Is that right?
Are there any 9"clutchplates with 9 Springs?
Maybe Fortwayne send me the wrong Pressureplate (6 Spings)....
Thanks for your help, Nico
Old 12-25-2018, 06:16 PM   #26
Brian
Brian's Avatar
No...all 9" pressure plates run 6 springs. You'll be fine with what fort wayne supply. And Merry Christmas to you
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 12-25-2018, 06:48 PM   #27
Nico73
Nico73's Avatar
Hi Brian,
at The early_ford_store of CA i found a 9" pressure-plate with 9 springs,
its item Nr. 48-7563.
That's make me thinking of, do i have enough pressure on the plate with only 6 springs
for the weight of my 1 1/5 Ton Truck?
How Big is the difference between 6 or 9 Springs in the pressure plate?
Has any one expience?
Thanks, Nico
Old 12-25-2018, 07:27 PM   #28
JSeery
JSeery's Avatar
Your truck is fairly light weight unless you are planning on adding something heavy to the back of it or carrying heavy loads. A heavy clutch is required with a truck preforming heavy duty work. For most of us this would not be the case with a restored truck.
Old 12-25-2018, 08:39 PM   #29
Brian
Brian's Avatar
Sorry Nico, I was unaware of such an item, however, I agree with what JSeery has written. I have also heard of individuals fitting 10" springs into a 9" cover to achieve a more 'robust' clutch. Maybe have the conversation with Fort Wayne?
Old 12-25-2018, 08:49 PM   #30
Brian
Brian's Avatar
Nico, I have a question for you- in the photo you posted that shows the 4 speed hanging on a sling, it appears that the clutch lever [operating arm] is facing down. Is that the correct orientation?
Shouldn't it be at 180 degrees to that?
Old 12-26-2018, 04:43 AM   #31
Nico73
Nico73's Avatar
Hi Brian,
oh, that's o.k. it just turns backwards when moving the gearbox.
Normaly it stands in up-direction :-)).
Thanks for your help guys, and you are right.
I dont want to bring him back to Heavy-Duty work.
My wife and me are slim People...;-)
Cheers, Nico
