Old 07-27-2017, 08:13 PM   #21
Barry B./ Ma.
Barry B./ Ma.'s Avatar
Default Re: Out for a short cruise . . .
Hi Stan, make sure you have all the teeth on the rear end ring gear, I had one break off of mine, make one loud clunk and clunked every revolution going home. I would get it up on jackstands and go from there, starting by loosening the rear adjusters and pulling the drums, let us know how you make out.
Regards,
Barry
Barry B./ Ma. is offline   Reply With Quote
Old 09-05-2017, 07:02 AM   #22
29Cabriolet
29Cabriolet's Avatar
Update:
Well, I finally gathered up all the tools and extra hands required to begin the repair project. After inspecting the trans by removing the shifter tower, and then inspecting the differential with a scope, the suspicion was moved to the U joint. We removed the rear axle and differential with the spring still attached because the differential has a leak and we thought this would be a good opportunity to replace gaskets. And sure enough the U-joint was in pieces! (I know we love photos here so as not to disappoint, check it out!) In addition to replacing that and hopefully the differential gaskets, the trans had been a little noisy due to normal wear of gears, mostly the main cluster. I don't feel good about putting it back that way when it's all apart. So a rebuild of that is on the list as well.
Any hints, advice, or dos and don'ts about any of the above will be greatly appreciated!
Thanks in advance!
Stan
29Cabriolet is offline   Reply With Quote
Old 09-05-2017, 07:16 AM   #23
JDupuis
JDupuis's Avatar
Glad you found it Stan. The u-joint is an easy fix compared to a major diff rebuild. Lucky"?" You. Jeff
Let's let pylons, be pylons!
JDupuis is offline   Reply With Quote
Old 09-05-2017, 10:10 AM   #24
RawhideKid
I am thinking there should be a LOT more grease in and around that Ujoint.
There is a reason that area is double gasketed and the grease fitting lines up with hole in the dome piece. Be sure that when you reinstall it, you start with it packed with grease and after installed, take the grease gun and finish packing it with grease.
Before Walmart you had to buy a ticket to the fair to see a bearded lady!
RawhideKid is offline   Reply With Quote
Old 09-05-2017, 10:56 AM   #25
29Cabriolet
Not sure about the quantity of grease - some was removed before the picture was taken. For the record it was installed over 30 years ago. I have ordered a "complete assembly ready to install. . ." I am assuming that would mean it's packed, but after install, I can hit it with the gun.
Thanks!
Old 09-05-2017, 11:02 AM   #26
RawhideKid
"Not sure about the quantity of grease - some was removed before the picture was taken. For the record it was installed over 30 years ago. I have ordered a "complete assembly ready to install. . ." I am assuming that would mean it's packed, but after install, I can hit it with the gun.
Thanks!"
Yea, just because they say it comes pre-packed with grease doesn't mean it's going to last another 30 years without adding the grease to keep it properly lubed. Think about it, there are 89 year old U-joints still running around because there have been proper maintenance done, which means continual packing with grease.
I believe the owners manual says to remove the speedo turtle and grease until it squirts out of that hole.That can be a LOT more than a simple tube of grease.
Old 09-05-2017, 11:30 AM   #27
Bob C
Check the shape of the new u-joint, some of them are not rounded enough
and will hit the inner u-joint cap.
Bob
Old 09-05-2017, 10:03 PM   #28
Tom Wesenberg
Tom Wesenberg's Avatar
Grease, we don't need no stinkin' grease.
Well, maybe a little Mystik JT-6 would help.
Old 09-05-2017, 10:32 PM   #29
SeaSlugs
SeaSlugs's Avatar
Yup grease grease and more grease. Altho mine spurted out like some terrible playdoh machine i KNOW its got plenty of grease. Glad your fixing everything else while the opportunity has risen.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 09-06-2017, 08:35 AM   #30
Barry B./ Ma.
Don't spare the grease Stan. I put about a full cartridge in mine. No wonder you heard a big bang!
Barry
Old 09-06-2017, 10:24 AM   #31
SeaSlugs
SeaSlugs's Avatar
Barry
yea I went thru about a 1lb can of grease for each U joint (AA - lucky me haha) I also coated the outside of the bell before assemblying the clam halves - sure the grease zerk lines up but I'm suspecting grease can/has to completely coat the outside of the bell or most of it before it forces grease thru the 2 tiny holes in the bell to fill the rather massive U joint cavity. Id rather have some spurt out upon assembly than too little grease.
Old 09-06-2017, 12:11 PM   #32
29Cabriolet
A club member suggested that some will mix 600W with the grease. The theory being that with the circular motion centrifugal force eventually sends the grease outward leaving much of the joint with less than needed. With the 600 added it is more fluid and keeps the joint better lubed. So I thought I'd poll the Barn. Any comments on this method?
Old 09-06-2017, 12:31 PM   #33
SeaSlugs
SeaSlugs's Avatar
if you jam it full of enough grease theres nowhere for the gease to "fling out" think of enough cookie dough (grease) in a mixing bowl (clamshell+bowl) going thru the beaters (u joint) - not all the cookie dough sticks to the outside...
Old 09-06-2017, 12:49 PM   #34
denniskliesen
denniskliesen's Avatar
I'm thinking about a full tube of corn head grease when I go back together with mine. I had very little grease in my old u-joint and the cavity when I took it apart recently. Surprised to find the old riveted u-joint still in good shape, no play in any of the joints. Maybe the transmission leak was just enough to keep it lubed.
denniskliesen is offline   Reply With Quote
