Old 04-15-2017, 05:39 PM   #21
cpf240
cpf240's Avatar
Default Re: part came out of the rear of the motor
It's like the story of the Apollo 13 guys playing a prank on Jim Lovell by changing the ratio of the gears in his new corvette. I don't know if its true, but it is a good one!
cpf240 is offline   Reply With Quote
Old 04-15-2017, 05:52 PM   #22
redmodelt
redmodelt's Avatar
Did you get the distributor issue figured out?
Old 04-15-2017, 06:32 PM   #23
1955cj5
1955cj5's Avatar
Originally Posted by lindy williams View Post
It looks like an old after market attempt at a rear main seal. I had an engine with one in it. It didn't work.
CRANKSHAFT MAIN JOURNAL SIZE STANDARD 1.6254/1.6259"
Quarter dollar = .954"
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 04-15-2017, 06:33 PM   #24
Dick Steinkamp
Dick Steinkamp's Avatar
I would agree that it has nothing to do with a part coming out of the engine. I can't think of a way something that size could come out of the engine and land in that drip pan. As Daveymc29 suggested, it could have been kicked up from the road, or been hiding on top of the trans/bell/flywheel housing and finally fell.
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 04-15-2017, 07:56 PM   #25
MikeK
MikeK's Avatar
Likely someone stuck an old shaft seal around the wishbone ball stem, in two halves, to temporarily "fix" a worn ball condition. It's just about the right size. Popped out right into the added drip pan!
Halftime score: Worn wishbone ball 1, Used-car mechanic 0.
MikeK is offline   Reply With Quote
Old 04-15-2017, 08:24 PM   #26
JBill
It even looks a little small for the wishbone ball. Could something on the road just been kicked up into your oil catcher? Grasping at straws here.
JBill is offline   Reply With Quote
Old 04-15-2017, 08:27 PM   #27
Sunnybrook Farm
Sunnybrook Farm's Avatar
Maybe someone had it around the ball of the wishbone and it squeezed out finally. Some thing rigged up?
Sunnybrook Farm is offline   Reply With Quote
Old 04-15-2017, 08:32 PM   #28
HammerSaw
Looks like a grommet
HammerSaw is offline   Reply With Quote
Old 04-15-2017, 08:39 PM   #29
Art Newland
Art Newland's Avatar
Maybe a home-brew brake rod anti-rattler?
Art Newland is offline   Reply With Quote
Old 04-15-2017, 09:51 PM   #30
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Kicked up from the road maybe?
Old 04-16-2017, 08:03 AM   #31
Tom F OHIO
Tom F OHIO's Avatar
I agree it looks like a Mode A grommet. Maybe the choke rod or one that goes through the firewall someplace and it fell in the pan.
Tom F OHIO is offline   Reply With Quote
