Old 12-01-2015, 08:11 AM   #21
FrankWest
FrankWest's Avatar
Default Re: Missing Door Screw
Originally Posted by Terry,OH View Post
10-32 X 1/4", oval head, slotted screw in S-2 (Raven finish). I believe it should have a external tooth countersunk lock washer 34952-S2. But it will work without the washer maybe use a small drop of locktite.
The dovetail is the chrome or bright nickel device below the hole missing the screw. The dovetail has a different screw.
Thanks. Should the screw be 3/4 inch long?
I also noticed that my back door is also missing a screw.
FrankWest is offline   Reply With Quote
Old 12-01-2015, 09:18 AM   #22
Terry,OH
Terry,OH's Avatar
Answer is above 10-32 X 1/4"
Old 12-01-2015, 09:59 AM   #23
FrankWest
FrankWest's Avatar
Thanks... Now I have to find that countersunk lock washer. Even the existing screw has no lock washer.
Old 12-01-2015, 03:03 PM   #24
FrankWest
FrankWest's Avatar
I have to special order screws with oval head...
I did purchase several screws without oval head to see if they fit.
One fit perfectly but the other door the screw would not screw in and would not fit totally thru the hole.
I am thinking of taping out the hole with the proper size and seeing if it will go in.
Hopefully that will re-establish the 10-32 thread, If not then I will have to tap with the NEXT larger size. What is the next size larger from 10-32?
Old 12-01-2015, 03:06 PM   #25
V8COOPMAN
V8COOPMAN's Avatar
#12, which is "roughly" 3/16". DD
Click Links Below __
T5 W/TORQUE TUBE
Old 12-01-2015, 05:07 PM   #26
Terry,OH
Terry,OH's Avatar
if you change to a #12 screw the head will be larger and not fit properly. Use a starting tap with a starting taper and go straight.
Old 12-01-2015, 06:03 PM   #27
FrankWest
FrankWest's Avatar
Good idea.. The hole seems tight for the proper size screw so maybe there is enough metal there to renew the thread.
Old 12-01-2015, 06:15 PM   #28
RobR'35
RobR'35's Avatar
It was common in the day to enter the car from the non traffic side.
Old movies from the thirties and forties show people entering from that side often.
Floor shifter was more towards the front of the car also to accommodate this as well.
RobR'35 is offline   Reply With Quote
Old 12-02-2015, 11:23 AM   #29
FrankWest
FrankWest's Avatar
I received the screws
Old 12-02-2015, 03:44 PM   #30
johnboy34
Sometimes a # 10 hole is too far gone, you can enlarge to # 12 and Roy does have #12 screws with # 10 heads. Macs also used to have them.
johnboy34 is offline   Reply With Quote
Old 12-02-2015, 04:05 PM   #31
FrankWest
FrankWest's Avatar
Good to know thanks...If they were not available I was already planning to shave the larger head down to be equal to the size 10 screw head if I needed to make a large hole.
Funny, my right side rear door latch had No screws in it but the threads seem good, I put a 10-32 screw in to hold the latch mechanism.
Old 12-02-2015, 08:41 PM   #32
Tinker
Tinker's Avatar
Originally Posted by FrankWest View Post
Roy Nacewicz at http://www.fordscript.com/ford_bolts/contact.html
is Fantastic!
He had everything I needed to complete my door latch screws.
He is the man..
He has such quality items too, look original!
Roy's a good guy. He will let you know if he doesn't have it and point you in a direction. Can't go wrong.
Old 01-09-2016, 03:02 PM   #33
FrankWest
FrankWest's Avatar
Received the hardware from Roy...They are beautifully made!
Roy is the best....His stuff is so beautifully made that I am tempted to buy an assortment of every item he has!
I had to tap one screw hole and the replacement screw and washer fit perfectly.
One other hole the screw was to loose..so I will have to tap that hole the larger size and buy the next size up screw to fit...
I have been told that Roy even sells a larger thread screw with the smaller size head of the original screws!! What an amazing guy! You gota love it when a guy..knows his stuff and throws himself into his work like Roy does!
Old 01-13-2016, 09:57 AM   #34
FrankWest
FrankWest's Avatar
Roy said he never had anything like this!!!
Old 01-13-2016, 10:25 AM   #35
TJ
TJ's Avatar
Dovetail is usually 1/4 20 slotted oval head.
Old 01-13-2016, 10:35 AM   #36
johnboy34
They are for windshield frame crank base! They are in the back of Macs catalog also.
Old 01-13-2016, 11:04 AM   #37
FrankWest
FrankWest's Avatar
I appreciate your help, but can't find it...Maybe I don't have the latest calalog.
I told Roy to send me his regular 12-32 1/4 in screws with regular size oval head and now he says there is no such screw used in the automotive field! Am I in the Twilight zone!
Should we be asking for 8-32 1/4 screws as the size large than 10-32 1/4??
Old 01-13-2016, 11:38 AM   #38
Steve/IL
Steve/IL's Avatar
Not Certain, but I believe that for #12 screws, Ford used 24 threads per inch not 32?
I've got the old car disease. Thankfully there's no cure!
Steve/IL is offline   Reply With Quote
Old 01-13-2016, 12:11 PM   #39
FrankWest
FrankWest's Avatar
Is 12-24 1/4 a larger diameter screw than 10-32 1/4?
Old 01-13-2016, 12:34 PM   #40
JSeery
JSeery's Avatar
Might want to look at a screw size chart.
