The Ford Barn
-   -   Missing Door Screw (https://www.fordbarn.com/forum/showthread.php?t=183839)
FrankWest 11-30-2015 06:15 PM
Missing Door Screw
1 Attachment(s)
For my 1933 fordor model B I have a missing Door Screw. I need to get another screw for this door.
Does anyone know what this screw is called so that I can order one.
JSeery 11-30-2015 06:26 PM
Re: Missing Door Screw
Not sure of the name, about everyone has them I would think. I would check with the bolt guy, Roy Nacewicz .
Willit Stop 11-30-2015 07:02 PM
I'm not very familiar with the 33's but it might be a set screw for the lock cylinder.If so, it is recessed in the hole in the door.
Bruce Lancaster 11-30-2015 08:06 PM
My thought too! Peer into the hole with a good flashlight. I think you will see a headless setscrew with a slot for straight blade screwdriver. It might also have been replaced with an allen headed one as used by Ford later on...both are 10-32.
Try moving it a bit and squirt on some oil, so it doesn't seize up.
FrankWest 11-30-2015 08:30 PM
I think you may be right!
Just looked at the other door and that hole is without a screw too!
Strange the hole is recessed like to make a screw head semi flat against the side panel?
FrankWest 11-30-2015 08:42 PM
1 Attachment(s)
This looks like the screw That is above the missing one.
http://www.macsautoparts.com/ford_me...kup-truck.html
Strange, but the screw above the missing one/whatever was partially screwed out??
ANYONE BELIEVE IN GREMLINS? Or do they only fool around airplanes?
V12Bill 11-30-2015 08:47 PM
I think that the missing screw is a screw that holds the latch assembly to the door. It appears to be a slotted oval head 10-32 X 1/2 or maybe a 1/4 - 20 by 1/2. You can measure the surviving screw to check for size.
FrankWest 11-30-2015 08:51 PM
I think what we need is picture of another 1933/1933 door to see if they have two screws
Tinker 11-30-2015 09:00 PM
Did they have locks on both doors in 33?
Might be different but not what I would say is the right lock screw. Bruce distribed it right.
I'd call Roy and check if he has them available.
FrankWest 11-30-2015 09:03 PM
1 Attachment(s)
Here is a photo of the door edge on another 33 car. Hard to see but it looks like there is something in both holes, shinny...a screw perhaps. I'm convinced there has to be a screw on either side of the lock! If not. I'll eat my Ford adjustable wrench!
Events like this make you appreciate how long ago this thing was made...It is almost like archaeology. Fun though, no rush..I'm not driving the car to Chicago tonight!
FrankWest 11-30-2015 09:12 PM
Just noticed that they only have a keyed lock on the passenger side!!
Strange...Never noticed that before...Never had an occasion to lock the car.
Why would the lock be on the passengers and not the drivers side.
I have an American left hand drive car...
Where is Rod Serling....This must be the Twilight zone.
Tinker 11-30-2015 09:15 PM
Pass side... So you could lock the car and not get run over in traffic :).
fourfords 11-30-2015 09:25 PM
I think the reason they put the door lock on the passenger side only was because in 1933 only a small percentage of the roads were paved. So entering and exiting the car was on the passenger side where there was a porch or walkway or sidewalk. This (I believe) was especially needed to stay away from the dirty and muddy roads on the driver's side.
And yep, each door on my '33 has two screws plus a slightly larger hole on the passenger front door to access the lock. I put a metal hole plug in mine to help keep dust out.
Tinker 11-30-2015 09:25 PM
Henry probably saved a few bucks too. ;) ha
Good info four fords. Makes sense.
FrankWest 11-30-2015 09:31 PM
Maybe for courtesy, letting your guest in first then have them unlock the drivers side.
The front of the car is especially narrow, because the running board takes up a lot of width, easy for your guest to reach over and unlock your door. Funny stuff..Never thought of this before...It's great...It was another time and another age..seems even more remote now!
FrankWest 11-30-2015 09:34 PM
Thanks...For your help...
These cars are great! I love them..They are truly from the distant past...It is wonderful. I love the clang of the metal doors and hood. It has an ancient feel to it...Not plastic like our cars today
Jay in Mass 11-30-2015 09:35 PM
Originally Posted by FrankWest (Post 1198463)
Just noticed that they only have a keyed lock on the left hand side!!
Why would the lock be on the left side and not the drivers side.
Yes you need another screw.
FWIW The left side is the driver side and, the right side is the passenger side.
This applies no matter where you are standing.
FrankWest 11-30-2015 09:43 PM
any know what those screws are called? are these
Dovetail Screws?
FrankWest 11-30-2015 09:47 PM
My mistake I should have read keyed lock passenger side, typed so fast was thinking one thing and typing another thing....Getting to old.
Terry,OH 12-01-2015 07:15 AM
10-32 X 1/4", oval head, slotted screw in S-2 (Raven finish). I believe it should have a external tooth countersunk lock washer 34952-S2. But it will work without the washer maybe use a small drop of locktite.
The dovetail is the chrome or bright nickel device below the hole missing the screw. The dovetail has a different screw.
