#21 | |
![]() Quote:
Can I just use a test light probe bought at autozone? |
#22 | |
![]() Quote:
#23 |
The rotor will only go on one way.
Bob |
#24 |
Points usually don't just stop working, but my car wouldn't start after setting for a few months with very damp weather. Even after I tried cleaning the points it wouldn't start. I hand cranked it and it fired right away and ran great. After running a few minutes all was fine again.
You can use any 6 or 12 volt test light, but it would pay to buy a good one for about $5 rather than one from the dollar store. I'm not sure how your 1933 ignition switch is wired, so I would need to see a schematic to follow the path of power to the coil, then from the coil to ground through the points. You can follow the path by starting at the battery and working towards the coil. |
#25 |
My coil looks like an original. Can the windings of these 80 years old coils really survive. I am surprised it worked at all. Have you every heard of electric stresses on these windings and insulations that could break down in use after becoming fragile for their age? I only hope I am able to see the terminal marking to connect the polarity right.I huess if I cannot, I will have to trace the wires to find the positive.
#26 |
