#21 |
I had this same problem back in the late 60's on an "A" and found it to be the front axle was bent. Took it to a front end shop and they had tools to bend it to get the right caster and camber.
#22 |
Cape Codder, I would also adjust the steering gear to take out the slop in the gears, just don't tighten it up too much or you will have hard steering. Put the front end on jackstands when adjusting the box. I had a low speed wobble in mine and the problem was the right hand steering arm was loose, those large nuts in the front must be good and tight.
#23 |
Don't forget to check the wiggling pin in the wobbling shaft
#24 |
Things to check. Loose steering gear, loose steering arm on steering gear, loose steering arm on front spindle, loose tie rod ends, loose drag length ends. maybe number one loose at transmission pivot ball on bottom of transmission that supports the radius arms from the front axle.
#25 |
Ray, Dog
![]() What's the part # uf thet pin & whar's it go? Then I can show Ol' Bill how SCHMADRT I am! ![]() Buster T. ![]()
#26 |
Paul in CT |
#27 |
Tire pressure was not off more than 2-3 lbs. when I aired them up to 34 lbs. before I went to the meet. I have had the car out one other time this year for maybe a 50-60 mile trip with no problems in the steering.
I do appreciate all the suggestions but I still have not seen a definite answer as to "how come at low speed and goes away at a higher speed"? Thanks for your time. Cape Codder |
#28 |
Just this weekend a member of our club had the "wobble" at low speeds but it went away at higher speeds. Her problem was what I mentioned previously: loose radius ball arms where they bolt into the spindles. I suppose it could be explained that at lower speeds there is less dynamics going on allowing the loose parts to wobble more pronounced, and at high speeds the higher dynamic stress keeps the parts in one position. Or something like that. Whatever the case, check those nuts where those arms bolt into the spindles! I'm tellin' ya more often than not I see these loose on a Model A nowadays.
#29 |
FWiw:
Who will win the "Dead Horse Award" on this Front End shake Question? Is something definitely loose as opposed to tight? Maybe Bill W's Buster-T can shed some canine light on this subject -- I know that my wife's dogs can often read human minds & offer advice, only if we are humble enough & willing to pay attention & read their canine expressions? Hope this helps. |
#30 |
A club member has the same problem. I changed his rubber wishbone ball cap to the original style steel cap. This helped, but didn't stop the shake completely. Everything feels tight in the front suspension and steering, so at this point I think he should remove the axle and check it for straightness by using the cones and 4 rods, as Kevin pictured in the past.
BTW, does anyone know of a source for the 4 cones, so I don't have to turn them on the lathe? ![]() |
#31 | |
![]() Quote:
![]() ![]() Guru Claude's inspection system in POST # 11 helps a lot to spot stuff & even to see what's goin' on KOOKY at thet RADIUS rod ball thingy. Vermin had all new frunt end stuff, but shimmied 4 times on "FUNNY" pavement in frunt of Bill Jones' house ![]() ![]() ![]() Buster T. ![]()
"THE ASSISTANT GURU OF STUFF" Last edited by BILL WILLIAMSON; 10-02-2013 at 03:54 PM. |
#32 |
Here is an update to my front shaking I thought some would like to read.
Well today I and a friend got into checking the front end for something loose. We did not see anything what I would call overly loose. I didn't want to over tight anything so after some consideration I looked further. What I found, which I still am unable to comprehend, is that the the rear of the tires were close to 1" more than the front. Yes I did say 1" so we got it back to 1/16" although I couldn't tell if I have + 1/32". Checked out with a ride and didn't have any problems of shaking. Will know for sure as we are going on a 2 1/2 hour tour to R.I, one way. Still don't understand this enormous discrepancy and still able to steer the car. Yes I still do have front tires. |
