Old 12-18-2014, 12:02 AM   #9
C26Pinelake
Default Re: Rumble seat conversion
Originally Posted by Purdy Swoft View Post
No it won't be easy, especially if you have never made such a conversion. You've got to drill and fit the hinges to the deck lid . you will have to get some threaded attachments installed in the deck lid. all of the holes must be exactly correct and a hole must be drilled for the handle and latch. all holes must be correctly placed and then you've got to make it all line up. I am an experienced bodyman. Some may tell you that it is easy I can tell you that it won't be that easy for a layman .
I have a friend that totally agrees with Purdy. He is not a body man and he took on the project to convert to a trunk from a rumble seat. He now refers to it as his Nightmare project. He doesn't even like to turn the light on in that part of the shop. Wayne
C26Pinelake is offline   Reply With Quote
