10-19-2010, 01:21 PM | #1 |
installing new distributor.
hi. im installing a new dist from bubbas. its the gm with pertronix and mech advance. motor is a 50 merc. when installing should the rotor point to #1 exactly or point a little after #1? the stock dist was set up this way when i removed it, this is why im asking, thanks.
10-19-2010, 03:02 PM | #2 |
Re: installing new distributor.
Actually it should be a little before number one in the rotation of the rotor. Anywhere close it ought to run, then adjust with the timing light.
Let us know how she runs. |
10-19-2010, 03:44 PM | #3 |
it fired first try the way i have it set now. when i put the timing light on it , the mark was about an inch before the pointer, is that about right? this is the first time ive installed a dist, i usually get a friend to help. they confuse me. my car is on the rack now so i can fix a few things, ill drive it in a couple days to really see the improvement over the stock dist. oh and thanks for the fast shipment.
10-19-2010, 05:21 PM | #4 |
We always remove#1 spark plug and turn the engine over until you feel compression.Then set the distributor to #1.It should be good enough to run,then you can set your timing with a light.
10-20-2010, 10:51 AM | #5 |
I tried to check my timing using a light, but it was so dim that I could not see anything. I was working outside, and I am running 6 volt. The engine in my '34 PU is an 8BA. What's next to try? Thanks, Byron.
IT'S NOT YOUR AGE, IT'S YOUR ATTITUDE ! |
10-21-2010, 09:48 AM | #6 | |
Would love to help but your question dont really fit into this thread, what distributor , what problem etc ???????????? |
10-21-2010, 10:54 AM | #7 | |
If you do not have an adjustable timing light you will need to mark the pulley at 6-8 and 10 degrees BTC. Measure the diameter of the pulley and multiply it by PI which is 3.14. Divide that number by 360 and you will have the distance of 1 degree on the pulley. Example: a 6 inch pulley multiplied by 3.14=18.84 inches divide that by 360 and you will have the distance of one degree. You can also convert it to millimeters by multiplying it by 25.4, 18.84X25.4= 478.536 millimeters divided by 360 degrees equals 1.329 millimeters per degree. Your probably going to be about around an 1/8" before the mark on the pulley at 8-10 degrees BTC. |
10-21-2010, 07:50 PM | #8 | |
( perfect for a flathead) |
10-24-2010, 12:59 PM | #9 |
ok, that makes sense. back out to the garage i go. thank you for the help.
