Old 12-01-2014, 07:36 PM   #1
beechboy
beechboy's Avatar
Default Water pump
Hello, I am going to get rid of my 4 blade fan and going to a new 2 blade. Will or should i remove the fan shroud now in place and just run the 2 blade? Not having over heating problems, the shroud was on the car when I got it. Getting scared of the 4 blade after reading on the Barn about them
Next question, I am going to rebuild my water pump, do you need a press to install the rear bushing. The manual says press the bushing in and line up the jerk area, but the manual didn't say you need the press that bushing out?
Thanks
beechboy is offline   Reply With Quote
