Originally Posted by Tom Wesenberg
I used electrolysis on my Cub Cadet wheel. It took two days and did an excellent job on very deep rust.
I agree with Tom. Electrolysis works great and the parts come out rust free.
Here's just one "How To" video;
http://youtu.be/y4yYF8gSHdA There is a lot of info on rust removal using electrolysis on the net.
IMO Sodium Hydroxide (NaOH) is too dangerous to use in a uncontrolled environment (Home use). It is a strong alkaline compound (very high pH) used in industry. It can and will burn you much the same way an acid will burn you.
Sodium Hydroxide is also used in drain cleaner.
