Old 10-06-2014, 10:10 AM   #1
billybronco1
Default Manual timing advance rod question - mine is all bent
I did not like the looks of the rod that runs from the distributor to the steering column, it is all bent so I looked at other engines and every one of them is straight. So I straighten mine out and noticed this must have been an adjustment because if I put the handle all the way down there is a gap on the distributor with remaining room to advance the timing more, maybe 1/8". What do you think is going on here? Is this normal? I have not attempted to adjust the timing yet.
billybronco1 is offline   Reply With Quote
Old 10-06-2014, 10:26 AM   #2
marc hildebrant
marc hildebrant's Avatar
Default Re: Manual timing advance rod question - mine is all bent
You can rotate the steering column some to make the spark and throttle rods work correct. Just loosen the clamp and turn some (not much).
Marc
marc hildebrant is offline   Reply With Quote
Old 10-06-2014, 12:57 PM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
If necessary, it's easy to cut & weld the rod to the proper length.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 10-06-2014, 06:33 PM   #4
ericr
ericr's Avatar
older repro versions of it had incorrect lengths
ericr is offline   Reply With Quote
Old 10-06-2014, 07:05 PM   #5
Skibb
Skibb's Avatar
Ericr, newer ones too....
Skibb is offline   Reply With Quote
Old 10-07-2014, 01:00 AM   #6
apbright
apbright's Avatar
Agree, the newer ones I recently obtained from Snyder's I found to be quite wrong. I was told by one fellow that the control arms (on the steering column, part A-3541) should be bent to correct for this, instead of bending the control linkages/rods, which presumably would be less ugly. Mostly, I was just happy to learn that I wasn't a total blubbering idiot for finding the control rod lengths to be wrong. For now, I have used those 'brass knuckles' adjusters to get the length correct. Eventually, I hope learn how to take Bill Williamson's advice (yes, I'm that new to this) to weld them to the correct length.
apbright is offline   Reply With Quote
Old 10-07-2014, 06:44 AM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
Bert's in Denver probably has a good original spark control rod. 800-321-1931
Old 10-07-2014, 10:07 AM   #8
harleytoprock
My Snyder's repro timing rod is also too long. Cutting and welding seems like the best cure since I'd have to rotate the steering column way too much to correct. The repro rod also measures longer compared to the corroded one that was on the car.
harleytoprock is offline   Reply With Quote
Old 10-07-2014, 02:51 PM   #9
hardtimes
hardtimes's Avatar
Hey billy,
Unless you are going for points car, yes you can use it as an adjustment ..I do !
Or you can loosen the steer column, and adjust, which I've also done. Not worth the trouble to me.
Or you can cut/weld to length, if you have a welder setup. Choice is good !
Old 10-09-2014, 04:19 PM   #10
billybronco1
Solution was turn the steering column slightly now my rod is straight and I have full spark advance, thanks for your help.
