Old 09-20-2014, 09:42 PM   #21
Russell in Tulsa
Default Re: Lets paly what is it!
MassAman, Yes that is a plumbers "Rope" for pouring a horizontal LEAD joint, not solder. And for your info, one that old may be asbestos. They are usually darker in color as we would soak in oil before using them. Just don't handle it too much as you don't want it to get the dust off of it near you or your family.
As to the gear thinga ma jig I have no idea.
Russell in Tulsa is offline   Reply With Quote
Old 09-20-2014, 10:53 PM   #22
MikeK
MikeK's Avatar
It is a homemade copy of Klipsich trip setter sorting tool for 20's era moving electric signage, as seen on theater marquees. The originals were cast bronze with an ebony tooth wheel. The two holes located the timing trip pins that held the setter for each individual lamp to the rotating drum switch. There were 41 (one blank + 40 "on" time delay positions. You are missing the small chime lever that tested each as they were sorted and put back in their storage trays.
Depending on the sign complexity, there were either 5 or 10 drums, each 7 to 21 slots high. The smallest model controlled a block of 11 watt sign bulbs 5 wide by 7 high. The largest (which could be duplexed, think Times Square) controlled a block of lamps 10 wide and 21 high. The blocks repeated around the marquis or building, wired in parallel. As the lamps blinked on and off, you got "moving or chasing" patterns or a message across multiple blocks.
On a special piece of Klipsich sign display planning paper, something like graph paper, you laid out the moving pattern. The paper then showed the time number setting (0-40) for each trip. It was up to the person setting the sign to manually count the vertical drum position that agreed with the layout paper, then the appropriate Klipsich trip was snapped in.
MikeK is offline   Reply With Quote
Old 09-21-2014, 11:32 AM   #23
Marshall57
Originally Posted by 34Fordtk View Post
LOL Great to see you guys had fun with it!!
I think I know,,,, one question was this model A ever driven to Hawaii? Because I think that is a Norse version of a Sextant, well just the degree part, the rest might have been washed overboard and that is why they had to return to the states.
Marshall57 is offline   Reply With Quote
Old 09-21-2014, 12:06 PM   #24
Mitch//pa
its a piece of wood with teeth on it
Old 09-21-2014, 12:58 PM   #25
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Made by Ben Franklin's DENTIST
Bill W.
"THE ASSISTANT GURU OF STUFF"
