Old 09-18-2014, 05:11 PM   #1
FrankWest
FrankWest's Avatar
Default engine enamel paint
Just recieved enamel green ford engine paint from MAC's for my model B engine. Supposedly good to 300 degrees F
No instructions on can!
Has anyone used this kind of paint?
I know about cleaning and degreasing the surface before painting but is there a primer?
Anyone familiar with engine paint?
FrankWest is offline   Reply With Quote
Old 09-18-2014, 06:23 PM   #2
J Franklin
J Franklin's Avatar
Default Re: engine enamel paint
Use a primer or wash with OSPHO and let it dry 24 hrs and paint. I like the later.
Old 09-18-2014, 07:14 PM   #3
harleytoprock
Cast iron is so porous that it doesn't need a primer. After the paint has dried, start the engine and let the temp come up to cure the paint and then cool. You can do these heat cycles a few times. If its an engine coming together on the stand, the heat cycleing can wait till you ready.
harleytoprock is offline   Reply With Quote
Old 09-18-2014, 08:12 PM   #4
Mitch//pa
primer is not needed with engine enamel
Old 09-18-2014, 10:17 PM   #5
J Franklin
J Franklin's Avatar
A watercooled engine should not get hot enough to burn off any paint, but I agree high heat paint doesn.t want primer. Did not think of porosity, or is it the rough surface that holds the paint?
Old 09-18-2014, 10:41 PM   #6
tbirdtbird
use no primer on an engine
'31 180A
tbirdtbird is offline   Reply With Quote
Old 09-19-2014, 11:09 AM   #7
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
A washdown with TSP will etch the old paint surface & allow the new enanemel to bond to it.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 09-19-2014, 11:51 AM   #8
700rpm
700rpm's Avatar
I was always told that primer just adds an unnecessary layer of paint to a block, and thereby inhibits cooling.
Ray Horton, Portland, OR
Old 09-19-2014, 12:23 PM   #9
FrankWest
FrankWest's Avatar
Thanks for your help! It is greatly appreciated!
Old 09-19-2014, 12:53 PM   #10
H. L. Chauvin
FWIW: POR 15 makes no recommendation for or against applying POR 15 undercoat prior to applying their POR15 engine enamel on cast iron.
Through experimentation, I removed all layers of old engine & transmission grease & paint, cleaned engine, head, & transmission case with POR 15 Marine Clean, treated with POR 15 Metal Prep, applied (2) undercoats of POR 15, then (2) coats of POR 15 Engine Enamel.
One can witness with many Model A engine photos that the standard engine enamels begins to break down immediately above & below the head gasket; however, when coated with POR 15 as described above, I've witnessed that this area immediately above & below the head gaskets will always appear like it was painted a few hours ago.
Maybe a few minutes more of the 3% painting time; but, absolutely no more of the 97% metal cleaning time; and just an example of having to do a Model A cleaning & painting task once in a lifetime.
H. L. Chauvin is offline   Reply With Quote
Old 09-19-2014, 01:01 PM   #11
Y-Blockhead
Y-Blockhead's Avatar
Does POR 15 have the proper Model A green??
Old 09-19-2014, 03:16 PM   #12
H. L. Chauvin
Hi Y,
I've compared "Ford Green" sold by different Model A vendors, (some in quart cans, some in rattle cans), & even though their Ford Greens are close to matching in color, I never found (2) that were identical.
POR 15 Ford Green is compatible with all other Ford Greens, but paint from different manufacturers will never be identical.
Furthermore, here is what I've learned with over 50 years experience with all types of paint.
If one orders 100 gallons cans of computer formulated paint from any one major U. S. paint supplier, no (2) gallons will be identical.
If one is re-painting the interior of a house with 10 gallons of the same color paint for example, it is best to mix all 10 gallons together to obtain one uniform color because later touch ups of blemishes with paint from a different paint can will appear like touchups & will be very noticeable to keen observers.
Hope this helps.
Old 09-19-2014, 03:42 PM   #13
Y-Blockhead
Thanks H. L., It does help!! A lot. I alway like a detailed engine.
Here's a picture of my 'other car's' engine, a '57 Y-Block (hence the moniker)
Old 09-19-2014, 06:42 PM   #14
700rpm
700rpm's Avatar
That's a nice-looking engine!
Old 09-19-2014, 11:38 PM   #15
Y-Blockhead
Thank 700rpm.
Old 09-20-2014, 06:23 AM   #16
Wallace
Yes, that is great detail in the engine area...especially nice exhaust manifolds...thanks for showing
Wallace is offline   Reply With Quote
Old 09-20-2014, 01:37 PM   #17
Flathead
Flathead's Avatar
Thanks for the info H.L. I've used Por 15 before, but not on an engine. I'm building an A engine now and may try this.
Mr Y-Blockhead, I have good memories of several 292's that I tortured unmercifully when I was a teenager, never got one to blow up. The Y-block doesn't get enough respect.
Flathead is online now   Reply With Quote
