How rare and how many 29 style fuel tanks had the 30-31 cap an why ?
Thanks Jerry |
Not that rare since Ford used the 1929 Body Style Truck until May of 1930.
I'm not aware of the actual start time of the new filler neck, but have supposed that this might have been done after October 1929 when Ford "anticipated" the new body style and started conversion of frame/chassis by lowering the pads for mounting the radiator (A filler piece was used for October through December cars using the old body style/old radiator.) IIRC (I would have to look back and confirm the engine numbers) I disassembled for parts a basket-case AA with the new style filler/old style tank and believe it was a November truck. But truck numbering is a little "flaky" compared to the car line with a 90 day leeway between engine number and actual production. This would be a truck convention only. I'm not aware that ANY passenger cars in the 29 body style were produced with the new filler neck. But stranger things have been observed... Joe K
Shudda kept the horse. |
Jerry,
Only production Early 1930 Commercial A's and AA's would have used the '29 tank with the Tab style Gas Cap. Since early Pick-Ups and the rest used the '29 Cab until they changed production to the '30 cab, there were also other early '30 commercial body styles that used that tabbed cap. Production records should show an approximate number of vehicles produced, not sure how they kept track of '30 production regarding the change. Darryl in Fairbanks |
My cowl has the door pos and the high profile header.
Meaning what? And what year does your car/truck purport to be?
Joe K
When the 1930 models made their appearance on December 31, 1929, the tanks changed with the exception that the 28-29 A-9002-A2 tank which was utilized with the AA Chassis and A commercial vehicles, including 76-A Open Cab; 79-A “A” Panel Delivery; 82-A Closed Cab; and 85-A “AA” Panel Delivery, except for the 150-B Station Wagon, through June 1930. Again, these tanks can be identified by the use of the 1930 “Easy-on” gas cap, filler flange along with the new style A-9020-B: Gasoline Tank Filler Screen Assembly with 3/8 inch wide tabs instead of screw threads. Ford also referred to the tank with the “Screw-on” gas cap as A-9002-A1. Go to my website and Additional Studies and see the articles on the Model A Gas tank. Pluck |
