Old 08-06-2014, 06:17 AM   #1
smittykid
smittykid's Avatar
Question Question on gas gauge replacement
I see that Snyder's sells an imported gas gauge assbly. for $38.75. They recommend a neoprene float & gaskets to counter-act today's corn liquor gas. I knew when I bought the car the gas gauge didn't work. I'm wondering if anyone out there has had any experience with the imported gas gauge assemblies. I'm trying to get my shopping list for Snyder's wrapped up. They are only about 2 hrs. from me. I plan on getting a luggage rack & trunk and I'm sure for what I'm going to pay for gas will more than make up for the shipping charges. Smitty
smittykid is offline   Reply With Quote
Old 08-06-2014, 06:32 AM   #2
mhsprecher
mhsprecher's Avatar
Default Re: Question on gas gauge replacement
The originals are pretty easy to rebuild. You could buy one and a rebuild kit and return what you don't use.
mhsprecher is offline   Reply With Quote
Old 08-06-2014, 07:00 AM   #3
Mitch//pa
i have used the complete units before with no trouble. that being said not much usually goes wrong with the original other than the cork float sinks so maybe just replace the float with the neoprene one. also use the cork gaskets on the gauge to tank as the rubber ones easily deteriorate from the ethanol.
Old 08-06-2014, 07:21 AM   #4
rscardina
rscardina's Avatar
Mine didn't work when I bought my car. The float was bad. Like Mitch said, there isn't much to them. The biggest problem that I have read here on the Barn is leaks after reassembly. I wanted to keep my old gauge so I replaced the float and it works fine. I borrowed the tool from someone in my club that made the job super easy.
Ryan Scardina
Livingston, Louisiana
1930 LSU Model A
rscardina is offline   Reply With Quote
Old 08-06-2014, 07:30 AM   #5
29Cabriolet
29Cabriolet's Avatar
I recently completed a gas tank removal and repair and in the process replaced the gas gauge gaskets and float. The float I used is neoprene but I found that it didn't fit tightly enough on the wire arm. Rather than soldering a washer to the arm, I fit the arm with just the right size roll pin from Lowe's.
29Cabriolet is offline   Reply With Quote
Old 08-06-2014, 08:17 AM   #6
Terry,NJ
Terry,NJ's Avatar
The gaskets and float are cheap enough. Nowhere near $38. The job is easy to do. You just need the special wrenches (2) and they're under $10 each.
Terry
Terry,NJ is offline   Reply With Quote
Old 08-06-2014, 08:38 AM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
Start soaking the gas gauge nuts with Kroil, as they can be stuck from old gas. Be sure to push in on the tools as you unscrew the gauge nuts, or the tool may pop out of place and scratch some parts.
Old 08-06-2014, 01:33 PM   #8
waxhead
waxhead's Avatar
As many have already stated, get a new neoprene float and gaskets/seals. Clean up the old one and put it back in.
Best to buy or borrow the right tool to do it up nice and tight to ensure it doesn't leak.
waxhead is offline   Reply With Quote
Old 08-06-2014, 01:48 PM   #9
Tom Wesenberg
I installed a customer's fuel guage once and his repro inner nut wouldn't screw in more than a thread or two. It was like the chrome made it too large. I hope that isn't the norm for the repro inner nuts.
Old 08-06-2014, 01:58 PM   #10
Clem Clement
Clem Clement's Avatar
Don't try the job without the special tools. Also there are cheapo version of the tools out there that I have had trouble with. Borrow a good set.
Clem Clement is online now   Reply With Quote
Old 08-06-2014, 08:38 PM   #11
KGBnut
KGBnut's Avatar
My gas gauge was leaking and the original gaskets had fused like iron. I couldn't get it apart. I didn't want to be without the car, so I got a used re-pop on eBay pretty cheap, and put it in temporarily.
I soaked my original in lacquer thinner for more than a week and it finally came apart (but I broke a piece off the dial in the process). I clean up and rebuilt the original, and used a generous amount of JB Weld to repair the broken piece. Then I repainted the dial. Once it was complete, the original went back into service.
I ended up driving for about a month with the re-pop. I was surprised that it was comparable in accuracy with the original. It also fit and looked okay...not great, but okay. However, it made a funny noise. It rattled...a lot.
I am holding on the the re-pop as a passable spare, but I would recommend rebuilding your original.
Oh, and for those who noticed that the neoprene float fits loose, I found that a little bit of a bend in the float arm wire is enough to make it fit snug.
Good luck,
Ken
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 08-06-2014, 08:54 PM   #12
Tiny
Tiny's Avatar
Really what you want is a neoprene float and cork gaskets.
Blackwall Panthers
Nor Cal chapter
Tiny is offline   Reply With Quote
Old 08-06-2014, 10:10 PM   #13
Drive Shaft Dave
The problem I had with a repop outer nut was it wouldn't thread in to the tank more than one turn. Went to my junk box of original gas gage part's and found an original outer nut, fit perfect. Not saying that all repro nut's are bad but this one was. Nothing like original part's.
Drive Shaft Dave is offline   Reply With Quote
Old 08-06-2014, 10:27 PM   #14
Mike V. Florida
Mike V. Florida's Avatar
I can't think of a single thing on the model A that is easier to get working again then the gas gauge.
Old 08-07-2014, 06:55 AM   #15
rocket1
They inner plated gas gauge nuts are no good,won't thread on due to plating,there is a clamping tool available so the wrench won't pop of large nut,it is held on by the 2 upper dash screws,also new lens is garbage not a magnifying lens just flat glass.
rocket1 is offline   Reply With Quote
Old 08-07-2014, 09:25 AM   #16
KGBnut
KGBnut's Avatar
Did the original glass magnify? That's news to me.
I just rebuilt mine, and have no reason to believe that it had been tampered with before... I had to get through 84 years of stubbornness to get it apart. And, I don't think that the glass was a magnifier.
Old 08-07-2014, 10:29 AM   #17
larrys40
The repro gauge assemblies are ok and fit function well, although, if you want the correct "restored" appearance I would restore an original gauge
Always assemble the gauge,glass, inner nut on the bench with the inner nut tight, and install the cork gasket and outer ring and nut once that's all done
I would recommend calibrating the gauge by bending the wire up or down so that when the tank is full and empty it registers as such
I install the neophrene floats on the arm with some thin stainless wire for insurance safety twisted nice and neat
Easy and enjoyable project as mike v says
Larry shepars
larrys40 is offline   Reply With Quote
Old 08-07-2014, 11:18 AM   #18
Dick Webber
I put a new float in mine. Don't remember what it was but it sank in about 2 years. Of course I threw away the original . . . . .
Dick Webber is offline   Reply With Quote
Old 08-07-2014, 12:42 PM   #19
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Some older repro gauges had PLASTIC lens that would melt, turn BROWN, & hang up your gauge & even LEAK!!!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 08-07-2014, 01:45 PM   #20
Clem Clement
Early Model A's had a convex lens as a magnifier. Later on the glass was thin and flat. Some repro kits have a thicker glass which is a problem.
