07-26-2014, 08:20 AM | #1 |
Cooler Idea? or just silly?
Having my coffee this morning and thinking about the heating of the Zenith 1. I wondered if there was some why to cool it... so being a computer guy, I was thinking of a heatsink to cool the bowl area... I found a place that makes plastic which can "stand the heat...." 300F.
So is this just silly and my coffee really bad and maybe I should switch brands
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio Last edited by mshmodela; 07-26-2014 at 08:12 PM. |
07-26-2014, 08:29 AM | #2 |
Re: Cooler Idea? or just silly?
switch brands this stuff will keep you sane, thats all dad and i drink... it makes all the other stuff taste like water
JET FUEL Last edited by Mitch//pa; 07-26-2014 at 08:49 AM. |
07-26-2014, 09:12 AM | #3 |
I had a Zenith several years ago that was painted gloss white. The heat gun showed it ran about 25F cooler. It was ugly, so it went back to black!
07-26-2014, 09:18 AM | #4 |
Let's indulge this idea a moment...
A finned heat sink is bidirectional. So, if you were to blow hot air across the fins, you would raise the temperature of the zenith carb bowl. If you blow cool air across the fins, you lower the temp. What defines the air temp is the reference of the carb bowl temp. So, you have to have air cooler than the carb bowl moving across the fins to make this work. On my Model A, I do not feel any air from the fan blowing across the zenith carb. The fan is above the zenith. The only moving air it would receive is when the car is in motion. I suspect the air moving through the fins with the car in motion will have come through the radiator already, taking with it the heat from the radiator fins as it removes heat from the coolant via the radiator. I'm not sure there would be a major advantage here. Especially when the car is stopped at a red light or parked on a hot day. I think your best bet would be to cool the fuel entering the carb. Perhaps a coil of copper fuel tubing that passes through a super coolant fluid before reaching the zenith carb bowl. Example- coil of copper tubing inside a coffee can full of ice water. Though, I would suggest you opt for a super cooled fluid more robust than simple H2O in its sub-zero state, which is very temporary. |
07-26-2014, 09:31 AM | #5 | |
07-26-2014, 09:31 AM | #6 |
07-26-2014, 09:35 AM | #7 |
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
07-26-2014, 05:53 PM | #8 |
Somewhere I have a picture of an experiment I tried and it worked well. I took an insulated beverage cooler and placed it around the glass sediment bowl. Drove the car in 107 degree heat for a week and scanned it with a thermal temp gun and compared it with my traveling buddies. Pot metal sediment top was 20 degrees cooler than my buds. car ran like a dream.
07-26-2014, 06:40 PM | #9 |
when u add your AC kit from Ken Davis you can have an accessory vent aimed out the firewall toward the Zenith
'31 180A |
07-26-2014, 07:19 PM | #10 |
The old coolcan from drag racing works, as does just taking a coffee can and putting a couple coils of fuel line inside and pack it with ice. Possibilities are endless ..... cold fuel keeps your carb happy.
07-26-2014, 07:38 PM | #11 |
07-26-2014, 09:24 PM | #12 |
I just drop a bunch of ice cubes in the gas tank. Keeps the gas & carb COOL don't you know.
