Old 07-18-2014, 05:38 PM   #1
AUTIE
Default No way Jose on starter removal
Tried to remove the starter today with the bendix still on and NO AH HA . Even though the coil assembly/magnets were removed, the flywheel was still in the way. So YES, you DO have to take the bendix off if removing the starter. Hope this helps out someone in the future.
AUTIE is offline   Reply With Quote
Old 07-18-2014, 06:02 PM   #2
billwill
Default Re: No way Jose on starter removal
You are doing wrong bendix will atay on the starter for removalgood luck
billwill is offline   Reply With Quote
Old 07-19-2014, 10:23 AM   #3
wbs
hello- I think that taking off the bendix is not bso difficult IF you remove the floor board 1st. take the cap off over the bendix, carefully as I think the screws have odd size. there is a ring with a small woodruff key. if tight, can be removed with very small gear puller. next there are 2 small tab washers. the rest you probably know.
wbs is offline   Reply With Quote
Old 07-26-2014, 08:16 AM   #4
bgarrett
bgarrett's Avatar
just wiggle the starter around until you are mad, then give up and it will fall out
bgarrett is offline   Reply With Quote
Old 07-26-2014, 10:29 AM   #5
J Franklin
J Franklin's Avatar
Just wiggle the starter around until you get mad and beat up your coil bundles on the mag ring! Take the bendix off and be carful not to damage the coils.
Old 07-26-2014, 08:45 PM   #6
redmodelt
redmodelt's Avatar
He does not have the magnets or coil ring in his engine. Read his whole post.
