Old 07-17-2014, 04:02 PM   #1
AUTIE
Default Starter removal
Stump the pro's or maybe easy answer . My T has a distributor and it doesn't have the magneto coil assembly/magnets installed. They were removed. Am I able to remove the starter WITH the bendix still ON or will the flywheel still be in the way? Not trying to be lazy (OK maybe just a little)...the starter has to be replaced and I only have the square gasket and I need it for this weekend so delivery won't make it in time. Could use form-a-gasket but if I don't have to remove the bendix cover it would be easier than doing it twice.
AUTIE is offline   Reply With Quote
Old 07-17-2014, 06:14 PM   #2
redmodelt
redmodelt's Avatar
Default Re: Starter removal
Yes without the magneto parts installed should be a snap.
Old 07-17-2014, 06:35 PM   #3
AUTIE
Thank you so much!.....I'll post the results.
