Old 06-24-2014, 06:08 PM   #11
Charlie Stephens
Default Re: $$$$ worth $$$$
Originally Posted by Harley03joe View Post
No The Owner Said It Was On The Frame, And Had Tpo Remove The Cab.
I Was Told That Vin # id Not Come Out Till The 50's And The Mod A Ford Used Body Numbers ?
Is That Right
Thanks
Harley03joe
The use of the term VIN did not come out until the fifties but prior to that they generally used the engine number or for some makes a serial number on a plate or a number stamped into the frame for a vehicle identification number. The Model A used the engine number. If you changed the engine you were supposed to notify the DMV. They did not use body numbers. The body numbers were only assigned to bodies that were not built by Ford and I believe your body style was built by Ford. Ask the seller to show you the body number that matches the title and sees what he does. Do not do anything with the car that involves investing money until the paperwork is straightened out. The owner was right about the number being on the frame (you have to lift the body to see it). This number should match the original engine serial number unless it has been replaced.
Charlie Stephens
