If your timing (cam) gear is turning when you use the crank to turn the engine, your crank gear is OK. But if that is what's happening and your distributor isn't turning, you have a stripped gear either on your camshaft or your oil pump drive.
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. ![]() |
