If you are new to Model A's and your mechanical abilities are low ,in my opinion, you should keep your "A" the way Henry designed them. Stay away from modifications and do not throw away any original parts. These old cars, "the way Henry designed them" are reliable drivers when rebuilt correctly.
Our club is helping out a new member get his car running. It is all original except for the paint. They keep telling me that he has no mechanical abilities, so they are going to modify it this way and that to help him out. I can't help but believe, they are steering him the wrong way. The parts they are discarding are easily rebuilt at less cost then new, and are just as reliable. As you can tell by now, I keep all of my A's as original as possible, but that's me. I am not against modifications, mechanics have the ability to modify, improve and maintain their vehicles, but for the novice these vehicles are in their simplest form the way Henry designed them. Most Model A'ers can help if there is a problem and it is original, but when modified it brings in a whole different set of knowledge. True or False
http://MODELABASICS.com/ How Things Work on a Model "A" Ford Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles. |
I think all a model A or most anything that's unknown to a person needs is the willingness to learn... I'm no mechanic... I deal with computers and software.... I have to figure those things out --daily...
I like my model a since it's a totally new subject to learn and it looks awesome!
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
It really depends on what mods are made. There are many improvements that can be made to any 86 year old design. I will list a few. A higher compression head in the 5.2 to 6.0 to 1 ratio will make a day and night improvement in hill climbing and driveability. The head can still appear completely original. A shortened pitman arm will make the steering easier, so will teflon buttons in the drag link and tie rod ends. There are at least 3 voltage regulators for the model A that is completely hidden either inside the generator or the cut out. Fun Projects makes several voltage regulators that mount in place of the troublesome cut out and requires no changes be made to the generator. One of these regulators will allow the use of 12 volts with no modifications to the original wiring or generator. A new modern barrel starter drive is available with no bolts to drop off in the flywheel housing like the old Bendix drive would often do. At least two styles of brake floaters are available. There is a longer clutch release arm that makes the clutch pedal 30% easier to depress. This is just a few of the mods that doesn't show or complicate mechanical matters in any way, in my opinion.
There is a difference between making mods because you want to, and making mods because you think you have to.
Totally agree with 30ccpickup .... look at the problems on this forum and a large percentage of them are related to ignition modifications. The original system with good quality points and condenser is almost bulletproof - a tuneup with new points, condenser, rotor and plugs can be done with a matchbook, dime and a couple of hand tools.
It can be done on the side of the road, it can be done in the rain, it can be done in the dark with a borderline flashlight. Throw in "new style" components and troubleshooting becomes problematic. |
"As you can tell by now, I keep all of my A's as original as possible, but that's me."
It's not just you. There are lots of us.
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. ![]() |
#8 | |
![]() Quote:
Thanks for posting. I would consider 6.0 to 1 head an advanced item. It is less forgiving, you need to understand your sparks advance and know the condition of your babbit. I believe I lost a couple of years of engine life from this rookie mistake. I guess my point is, if you are new to the hobby and do not understand what is best, you will not hurt the car by keeping it original. There is always time to learn and alter it to your personal liking later. You will know why you are doing it and not because someone told you it was better and some may choose not to alter it at all. Paul
http://MODELABASICS.com/ How Things Work on a Model "A" Ford Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles. Last edited by 30ccpickup; 06-16-2014 at 08:26 PM. |
#9 | |
![]() Quote:
Chet |
From the perspective of someone who was a newbie 2.5 years ago:
- I HATED that some previous owner had re-wired things, differently from standard. Made troubleshooting the intermittent short I had a year ago near-impossible. I ended up ripping out a bunch of wires and getting it back to standard. - Adding a voltage regulator (ended up getting the Fun Projects one) was one of the better additions - I knew nothing about the possibility of overcharging the battery, until it was too late. Now, I don't have to put a second (or even first) thought to it. - I like the peace-of-mind of fusing the various accessory circuits (e.g. lighting). - Likewise on having a battery cutoff switch. - I absolutely had to have a third brake light, and changed the teacup lights to red instead of amber. No one at all nowadays equates amber lights to braking. - Mine came with turn signals - probably a good thing as well. - It also came with a 5.5 head. Not having anything to compare it to, I just have to assume it's an improvement. I've climbed some hills with it, and it does respectfully, but nothing to write home about. I've thought about adding an oil filter, but given how little I drive (maybe 10 miles a week, on average), figure it's probably not worth doing. The one thing I do want to add is a trunk - having some storage space for spare parts/tools without piling stuff into the passenger compartment would be nice. My preference would be for something like a Kari-Keen, with moving the spare to a fenderwell a second choice. Adding the trunk behind the spare is a no-go. It came that way originally, and was fugly as hell (not to mention that it made it impossible to get the spare off without removing the trunk rack). |
#11 | |
![]() Quote:
The same old issue, and the same two camps are still here.....as usual, there is no right answer, but some common sense helps. Some guys are born to tinker and improve things....others, no. I even know a few folks who do not own a computer or a cell phone and are proud of it.
Some of us with Model A's take a moderate approach, making a few select changes that either enhance road performance in a modern world or for safety, without losing the character of the car or it's function |
#13 |
I didn't know anything about a Model A when I bought mine. Then the starter broke and I learned how to fix it. 53 years later I've fixed most of it. Still all original, but I do believe in the fuse attachment, and I added an extra tail light. Now I'm overhauling my first engine, a Model A Gordon Smith air compressor.
What a trip! A life time of pleasure from just an ordinary 29 tudor sedan driver. |
#14 |
being mechanically inclined (no expert , self taught) i find working on mine relaxing & just plain fun . i have many mods , but thats my personality . i drove stock for many years before i changed a thing . yes i have screwed up a time or 2 , but thats the challenge & fun for me ............
V4f |
#15 |
I think I have commented before that my Dad's contemporaries, all of whom are long since deceased, who owned these cars when new or slightly used, stated that the cars would run-run-run with a minimal amount of maintenance. They were reliable and economic. Most of our problems with them seem to arise from lower-quality repair parts or repair procedures now longer practiced or impossible to perform due to absence of the original tools.
#16 |
I would have to agree with 30ccpickup. For the most part original is much easier to deal with. I have a bit of "wrenching" experience but not all that much with A's. I rely for the most part on Les Andrew's books and input from club members. Other than a few of the more common mods such as the fuse block on the starter I prefer to keep my car stock. If I need to repair something and it doesn't match the book it really makes life difficult. As a few have stated once you get the feel for what you are doing (and that probably takes YEARS) venturing out into Modville isn't nearly as risky!
Pete - Orange County Model A Ford Club "If I asked people what they wanted they would have said faster horses." -Henry Ford |
#17 |
#18 |
One with one without!
With, harder to hand crank and not as low of an idle. Without easy hand start and real low idle while stopped at lights.
#19 |
Still a modification and it was your choice. There is nothing wrong with reasonable mods for a driver car. The ones that I have with brumfield heads crank good with the hand crank but probably don't idle quiet as slowly as Gus, my rusty 29 tudor, my 31 tudor or my sept. 29 strip down with stock heads .
#20 |
I have installed a laycock overdrive unit and an alternator. The rest of my A is stock. My rule is that whatever modification done you have to be able to put the A back to stock condition. There is no right or wrong ---just what the owner is happy with....
