Old 06-05-2014, 01:19 PM   #1
40Ford!!
40Ford!!'s Avatar
Default What year is this cab?
Guys, I have a Ford truck cab and I was told it's a 40, but I read somewhere that if the gas filler is on the passenger side it's NOT a 40! So mine is on the passenger side and now I am wondering what year it really is? Thanks!
40Ford!! is offline   Reply With Quote
Old 06-05-2014, 05:37 PM   #2
Herman Munster
Herman Munster's Avatar
Default Re: What year is this cab?
A photo would help too.
1956 Ford Fairlane Town Sedan 292 V8 with Ford-o-Matic
Herman Munster is offline   Reply With Quote
Old 06-08-2014, 08:51 PM   #3
46yblock
46yblock's Avatar
My understanding is that cabs were/are the same between 40 and 47. They are also the same for 1/2 ton and commercial truck. Many '42-'47 pickups were scavenged for their cabs, for use on the 40-41.
The 38-39 cabs at first glance look the same too, but they are signficantly different.
My '46 has the gas filler on the passenger side. IF the 40-41 was on the DS, it wont make much difference whether or not it is used on the earlier or later 1/2 tons. Like above, pictures help.
Mike, S. Oregon 46 Ford 1/2 ton, '62 Merc Meteor S33, '54 Ford 600 tractor, '64 Falcon Futura, 1960 Thunderbird
46yblock is offline   Reply With Quote
Old 06-13-2014, 05:20 PM   #4
40Ford!!
40Ford!!'s Avatar
Right, sorry about that. This is a shot of the cab but I have already filled the filler hole as the new tank will be mounted in the bed.
Old 06-13-2014, 05:28 PM   #5
46yblock
46yblock's Avatar
From that angle it looks like a 40-47 cab to me.
Old 06-13-2014, 05:48 PM   #6
40Ford!!
40Ford!!'s Avatar
Thanks for the input. I thought it was a 40 but someone told me the 40 had the filler on the driver side? Probably doesn't change anything I was just curious. Here is another view, yes the cab is chopped. I took out 3.5" to build a hot rod with my daughter.
Old 07-26-2014, 07:33 PM   #7
41LjH
41LjH's Avatar
Ford 1/2 ton did not have a filler on the cab till 1942. both 40 and 41 tanks were below the bed behind the rear axle with the filler neck in the driver's side rear fender. Otherwise the cabs from 40-46 were very similar. The dash is a good way to tell, A 40 has a raised rectangular section in the center and 41-46 have a flat dash. If your cab has a hole in the B pillar for a filler neck it is a 42 or newer.
3 pedals, 3 gears, no valve-covers..
Now THAT is a hot rod !!
https://www.youtube.com/watch?v=ZmwwB34vxJE
41LjH is offline   Reply With Quote
Old 07-28-2014, 08:58 PM   #8
by3
Interesting.
by3 is offline   Reply With Quote
