Old 05-22-2014, 06:18 PM   #1
gridleak
gridleak's Avatar
Default Re: water pump removal
I got it off without removing radiator but I had to cut off one of the fan blades. This wound up not being a big deal as the woodruff key had turned inside the fan cutting a groove half way around so the fan was toast anyhow. Shaft was ok.
Any want t try a three blade fan. Its a bit off balance
gridleak is offline   Reply With Quote
