Old 05-13-2014, 11:53 AM   #1
40a-760
40a-760's Avatar
Default help with 1934 parts source
I have been unsuccessful in my search for sources for the following parts;
1. 1934 cabriolet header seal (part #40 761440).
2. the small bare metal plates that are found on each side of the outer edge at the top of the body channel that the rumble lid seats. The plates are approximately 1 1/4" high by 3" in length and are held in place by a single screw / bolt and I am guessing that the keep the lid from moving side to side. The nomenclature of this part and a part number would also be of help.
Any help to locate these parts would be greatly appreciated.
Walt K. in PA
40a-760 is offline   Reply With Quote
Old 05-13-2014, 01:35 PM   #2
34billct
34billct's Avatar
Default Re: help with 1934 parts source
Guide ( Deck Door ) 40-713970 ???
34billct is offline   Reply With Quote
Old 05-13-2014, 01:45 PM   #3
40a-760
40a-760's Avatar
34billct,
Thank you for the information on the rumble lid part. Do you know if the part was ever reproduced?
Old 05-13-2014, 05:20 PM   #4
Zimmco
Zimmco's Avatar
Left to right on the first photo: 1-original worn out, 2-NOS (came in black on front, no paint on back, 3-blank aluminum, 4-homemade repro. The second photo is an edge view, showing the taper from the bottom to the top. A 1/4-20 flathead with a nut and lockwasher is used to mount them. Countersink the hole before tapering. The hole is large enough to allow the flathead to end up below the surface. Trim the blank to size, drill, countersink, then taper, polish and paint. I believe body color would be correct. If you want an installed photo, let me know.
Zimmco is offline   Reply With Quote
Old 05-13-2014, 10:36 PM   #5
40a-760
40a-760's Avatar
Zimmco,
Thank you very much for the sketch and photos. The information is exactly what I was hoping to find. Your offer of a photo of an installed guide would also be of help.
Again, your assistance is greatly appreciated.
Walt K. in PA
Old 05-14-2014, 04:39 AM   #6
FlatheadTed
FlatheadTed's Avatar
Try Ed solare
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 05-14-2014, 07:43 AM   #7
jim1932
jim1932's Avatar
Have you tried Dick Spadaro? If he doesn't have it, he will know if it is available.
Jim
Short URL: http://smu.gs/14g7eDW
jim1932 is offline   Reply With Quote
Old 05-14-2014, 08:26 AM   #8
40a-760
40a-760's Avatar
Ted,
Thanks for the lead on the guides.
Walt K. in PA
Old 05-14-2014, 09:18 AM   #9
40a-760
40a-760's Avatar
Jim
Jim,
Never thought to call Dick Spadaro, who is a 'go to guy'. Will check with him today.
Thanks for the lead.
Walt K. in PA
Old 05-14-2014, 12:06 PM   #10
Zimmco
Zimmco's Avatar
Here's a photo of a guide installed. The lid doesn't touch this one, and just barely touches the one on the right.
Old 05-14-2014, 01:25 PM   #11
40a-760
40a-760's Avatar
I sincerely appreciate the additional photos and your willingness to help.
Walt K. in PA
