Hey guys, does anybody recognize the markings on this cylinder Head? I don't, and if its aftermarket I don't really want to put it on my car. Thanks for your help!
I am taking a guess here, but the symbol to the right of the "F1" looks to be "MF" (where the M and F use a common leg of each respective letter). As an antique tractor enthusiast, that says Massey-Ferguson. Their MF symbol used the same technique.
Remember, I am just guessing.
Ron/IA 1929 Fordor Steelback Hawk A Model A Ford Club http://hawkamodelaclub.org/ |
What does the water pump mount look like? 3 or 4 bolt pump?
Blackwall Panthers Nor Cal chapter |
The 6-21 looks like a date code of June 21
Actually I think it is a rare, Ford Model A Formula One head, used in Gran Prix racecars home build for Formula One competition in the war years.
6-21 is actually 6.2-1 compression ratio. The cars campained successfully until they were discovered to be using illegal muffler bearing. Sorry...it's Friday afternoon.... ![]() ![]() ![]() ![]() ![]() ![]()
RobertB Santa Teresa, NM |
Larry Seemann |
Can we get pix of the combustion chamber?
Joe K
Shudda kept the horse. |
Thank you for your responses and knowledge!! I will get you other pictures tomorrow as the head is down at my shop. I would be interested in selling it if anybody has an idea on its value. I was planning on having it surfaced, blast, prep, and paint it ford green unless that would be a mistake.
Vince has it listed on his compression ratio chart but no information on it.
http://www.fordgarage.com/pages/head...ssionratio.htm Bob |
#10 | |
![]() Quote:
Charlie Stephens Last edited by Charlie Stephens; 02-23-2014 at 07:48 PM. |
Here are the pics of the combustion chamber. Any further info you can give me I would greatly appreciate. Thank you!
Additional picture
#13 |
Hmm. It doesn't seem to be anything special. Maybe the numbering WAS a date code?
Only real way to tell is with a graduated cylinder. Here's a standard Model A head compared to yours. Joe K
Shudda kept the horse. Last edited by Joe K; 04-13-2014 at 12:34 AM. |
#14 | |
![]() Quote:
I'm with Joe's evaluation here, in that, it looks about the same comp ratio as a common stock model a head. Probably produce same good sound also ! If no cracks and you are not looking for high comp, I'd flatten it and run it ! |
#15 |
The head is a stock aftermarket head. Nothing special about it except if you try to use it with oversize intake valves the valve will hit the side of the combustion chamber in the head. To recognize a factory Model A head look on top of the head behind the waterpump and the water outlet for a stylus mark that looks like a small bump which is longer than wide. All factory heads I find have this mark.
http://www.model-a-ford-4bangers.com/ |
