I fired my rebuilt French motor, and had a problem with misfiring, and after a round of changing caps etc, I found the problem to be with the rotor arm. This was a black "made in USA" rotor arm bought either from Macs, but more likely one I got from Napa.
This rotor ran great last year, but this year it just didn't want to work. The motor would run at a fast idle and then just suddenly stop. After cooling a bit, it would start again. Not the best situation when I wanted to get a good 20 minutes on it to break in the new cam. A few years ago I went through a round of this with the Lucas rotors, I thought I'd got this licked when I swapped to the Crab. Anyway, here's a pic. ![]() You can see the burnt/charred/darkened area around the 10 O'Clock position. And another one. ![]() Harder to see, but the slightly darkened "7" shape inboard of the first leg of the "M" shows the leak path. So, I post these to alert you all to the possibility of failure, but also to ask is this common? Are these prone to failure? Is there a better one out there? I thought these were the best. Mart. |
Mart,
Pretty rare for a black rotor of any brand do that. I would be very carefull and look at the entire secondary ignition system. Something is calling for a very high voltage demand . Check the coil wire and all connections, plug wires etc , also a lean ( like in air leak) air fuel will ask for more voltage.... |
Might be a bad rotor, but first carefully examine cap, wires, and plug gaps...if you have a gap or high resistance somewhere affecting anything from one cylinder to all, it can force a misfire through whatever is the weakest other link.
At least with a crab, phasing should not be a problem...that should be built in right out from the camshaft. |
Thanks fellas. I will investigate further.
One thing I did notice, was that when I held a grounded screwdriver blade near each "cap" (actually completely exposed oe ford terminal ends) I got a good fat spark on most leads, but a weak spark on a couple of them. I need to look carefully at the leads and cap. The plugs were changed for new ones. Mart. |
#5 | |
![]() Quote:
![]() ![]() ![]() Mark, I have read your treads in the past, I know you will get this fixed, you know what your doing and we will all learn from it ..... thanks ....OLD...BILL ![]() |
I suppose the lesson learnt is to ALWAYS CARRY SPARES!.
Thanks for the input. Mart. |
