Old 04-06-2014, 09:56 PM   #1
tbirdtbird
Default Re: Rear Axle Hub Key
"Seems like the physics of the thing should work so that as the axle nut is tightened the washer pushes against the outboard end of the key to lock it into the hub as the inboard end of the key (with the taper) presses into and upward against the taper of the broached axle slot. "
yes, and don't forget the special 5/8 grease seal, there is a recess machined into the hub to receive it. It somewhat resembles a garden hose rubber washer in size and shape
'31 180A
tbirdtbird is offline   Reply With Quote
Old 04-06-2014, 10:02 PM   #2
29er
29er's Avatar
Tbird: Gotcha! Thanks to all for the lesson!
29er is offline   Reply With Quote
Old 04-07-2014, 07:07 AM   #3
Afordman31
Afordman31's Avatar
I do it like tbirdtbird does. Afordman31
Afordman31 is offline   Reply With Quote
