Old 03-29-2014, 01:01 AM   #1
CJH
Default Unsusal Find
I am helping a friend work on his 1930 coupe and found this unusual brake drum / hub. Can anyone identify it?
Chris
" . . . these changes aren't permanent, but change is." - Neal Peart
CJH is offline   Reply With Quote
Old 03-29-2014, 01:12 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Unsusal Find
Commonly called the Rocky Mountain brake drum. Is it 12" or 11"?
It's cast iron so it doesn't have the brake fade of the steel drums.
Old 03-29-2014, 01:44 AM   #3
H. L. Chauvin
I have two (2) original brake drums that look very similar on my Model B front axle that my Uncle used to make a boat trailer in 1932 -- think the drums are 12" inside diameter -- never removed them since 1960 or 54 years ago ............ CRS could be possible after 50 years in many cases.
H. L. Chauvin is offline   Reply With Quote
Old 03-29-2014, 06:18 AM   #4
Brian SATX
Brian SATX's Avatar
Used on new cars late in 31. Better than the solid drum.
Brian SATX
Brian SATX is offline   Reply With Quote
Old 03-29-2014, 09:17 AM   #5
Purdy Swoft
Purdy Swoft's Avatar
If the inside diameter is arround eleven inches it is a late 31 cast iron drum. If it is 12 inch inside diametyer it is 32 or later.
Old 03-29-2014, 06:57 PM   #6
CJH
Thank you for the help gentlemen. I do not have the drum here at my place. I will measure it when I see my friend again to do the brake job on his 30 coupe.
Chris
Old 03-30-2014, 01:24 AM   #7
ctlikon0712
ctlikon0712's Avatar
I have 3 of them and can tell by the amount of material just passed the 5 spokes that it is an 11" drum. Nice find.
Wanted: Simmons Super Power Head
Craig Likon 1931 150B
ctlikon0712 is offline   Reply With Quote
