Old 03-27-2014, 11:19 PM   #7
700rpm
700rpm's Avatar
Default Re: Rookie with an engine problem
I use a tapered wooden dowel to hold the pump up while installing a pan from underneath, then remove and replace the plug. No danger of damaging the pipe thread this way.
Ray Horton, Portland, OR
