Old 03-27-2014, 01:14 PM   #1
glenn in camino
glenn in camino's Avatar
Default Front backing plate castle nuts, finish
The judging standards says that the front backing plate bolts are unfinished, but doesn't mention the nuts finish.
Old 03-27-2014, 02:54 PM   #2
wrndln
Default Re: Front backing plate castle nuts, finish
I am pretty sure the nuts are also unfinished. I usually spray a clear sealer, like rattle can dull or flat clear lacquer, to keep the nuts and bolts form rusting for a while.
Rusty Nelson
Old 03-27-2014, 08:23 PM   #3
Hunter
Rusty is correct. Unfinished.
Hunter is offline   Reply With Quote
Old 03-27-2014, 10:22 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
I've sprayed bare metal hardware with Dutch Boy Fresh Look Acrylic Enamel 3733 CLEAR. The can doesn't say "semi-clear", but I suspect that's what it is because it doesn't give the nuts that glossy look, but rather a natural look.
