Old 02-27-2014, 11:14 AM   #41
RockHillWill
RockHillWill's Avatar
Default Re: 30 Pickup Sheetmetal Work
Nice work Flop!
Uncle Bud says "too soon old, too late smart!"
RockHillWill is offline   Reply With Quote
Old 03-13-2014, 07:47 AM   #42
Flop
thanks Will!
truck is almost done and will be heading back to New Jersey soon !!
some new some old . still gonna put some poly on it to protect it
and fords newest see through door . i dont like where the previous person cut the skin off but i will make due
Please call or email while website is down!
412 867 1659
[email protected]
https://www.facebook.com/flop.custom
Flop is offline   Reply With Quote
Old 03-17-2014, 07:55 AM   #43
Flop
start of the door skin
time to start working on fit
with a place with little to no hammer access you want the best possible fit in the world .
welded up
412 867 1659
[email protected]
Old 03-17-2014, 09:06 AM   #44
Dave72dt
That cut line really is close to the body line! I'll guess it was recut to get it straight. Was some crown wheeled into the panel before or after the lower body line work? Always enjoy the tech posts.
Dave72dt is offline   Reply With Quote
Old 03-18-2014, 08:14 PM   #45
Flop
i went close to that line to prevent warpage Dave due to no hammer access!
how bout some color!??!
into epoxy
door i put the full skin on !
412 867 1659
[email protected]
Old 03-18-2014, 08:23 PM   #46
bart78
bart78's Avatar
Man that looks good. Probably the best it's ever looked.
bart78 is offline   Reply With Quote
Old 03-18-2014, 10:26 PM   #47
28ACoupe
28ACoupe's Avatar
Originally Posted by 1930 coupe View Post
How do you put the compound curves in the large panels?
Practice and patience.
1928 Model A Business Coupe
Rebuild picture gallery here
The light at the end of the tunnel has been turned off due to budget cuts.
28ACoupe is offline   Reply With Quote
Old 03-19-2014, 06:45 AM   #48
Vin-tin
Vin-tin's Avatar
Flop, as ask previously... Did you wheel a crown in that door skin, or was it all done from the edges with a shrinker?
1929 Coupe
1930 Coupe
1935 Ford 5 window coupe
Vin-tin is offline   Reply With Quote
Old 03-20-2014, 05:56 PM   #49
Flop
thanks folks !! all crown or curve in put in with a wheel on the low crown panels . slight shrinks on the edges .
412 867 1659
[email protected]
Old 03-20-2014, 07:39 PM   #50
JackA
JackA's Avatar
You are braver than I!
JackA is offline   Reply With Quote
Old 03-23-2014, 07:07 AM   #51
Flop
thanks every one !! all tied up on my end minus a few screws and bolts!!
412 867 1659
[email protected]
Old 03-23-2014, 12:09 PM   #52
Bob C
That looks beautiful. Did you use new roof panels above the doors, if so how well
did they fit.
Bob
Old 03-24-2014, 08:35 AM   #53
Flop
thank you bob!!
the edge about the door needed stretched to take some curve out of it because the door wouldnt shut . And as you can see in the picture the front where it nails down doesnt line up . I rewelded that area after the picture to make things line up . They are a very nice piece though and well worth the price .
412 867 1659
[email protected]
