Old 03-01-2014, 12:01 AM   #6
Marco Tahtaras
Marco Tahtaras's Avatar
Default Re: PROS and CONS of a high compression head
They are a great addition. They don't do a good engine any harm. However owners ARE more likely to cause harm primarily due to improper use of timing advance. The low compression on the stock engine is very forgiving of misuse. The higher the compression, the more critical the proper use of timing becomes.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
