Old 02-28-2014, 03:01 PM   #1
Pete Fl/Wi
Pete Fl/Wi's Avatar
Default Too much compression??
I bought this 276 CI that had been in storage for at least 15 years. It came with Edelbrock heads and a 4 duce Sharpe intake. I stripped it down to a short block, had Skip rebuild the pumps, put a Rochester 2gc on a merc 4 bolt and a set of EAB heads. Used the rolled up aluminum foil check for clearance. On my test stand it ran fine and sounded strong. Ran it on and off over a week sometimes for close to an hour. Only thing I noticed not perfect was a little blue smoke if I jazzed the gas. After my last run I checked compression while it was still warm.
5---142 160---1
6---131 155---2
7---121 151---3
8---143 152---4
How does that compression look to you guys??
Thanks
Pete
Pete Fl/Wi is offline   Reply With Quote
Old 02-28-2014, 04:32 PM   #2
flatheadfan
flatheadfan's Avatar
Default Re: Too much compression??
I can't speak for others it doesn't seem right. It is my understanding the variation between the highest and the lowest readings shouldn't be more than 10%. Several cylinders don't fit the rule.
Tom
flatheadfan is offline   Reply With Quote
Old 02-28-2014, 04:49 PM   #3
51 MERC-CT
51 MERC-CT's Avatar
Yep, don't look right. Rule thumb--"As a rule, most engines should have 140 to 160 lbs. of cranking compression with no more than 10% difference between any of the cylinders."
Old 02-28-2014, 06:36 PM   #4
flatjack9
flatjack9's Avatar
Put some oil in the low cylinders and see if the compression comes up a little. Could be some stuck rings from sitting so long. Personally, I'd put it in a car a drive the H--- out of it.
Old 02-28-2014, 06:59 PM   #5
Talkwrench
Talkwrench's Avatar
I could be wrong here but I'm sure I read that some heads inc eddies have different chamber sizes for left and right, I see one side up and one side down. Walt, John?
Old 02-28-2014, 07:02 PM   #6
rotorwrench
rotorwrench's Avatar
If it's running on all eight, put it in something and pull a load with it. At least it's hitting on all eight and all the compressions are above 120 psi. Marvel Mystery Oil in the low ones might loosen the rings & valves a bit. Put some in the fuel tank too.
Old 02-28-2014, 07:08 PM   #7
alan
new engine, with the slight blue smoke, maybe has not completly seated the rings? revv up and let off--revv up let off--etc--do this for awhile trying to seat the rings, when you check compression check, wide open throttle and put a squirt of oil in each cylinder as you check compression-as when it is running oil is splashing the lower end of cylinder bore
alan is offline   Reply With Quote
Old 02-28-2014, 07:38 PM   #8
Ross F-1
Ross F-1's Avatar
Until there's a load on it, you're just wearing the rings out to run it.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 02-28-2014, 08:24 PM   #9
Ol' Ron
Ol' Ron's Avatar
Looks to me that the drivers side head has a larger combustion chamber, or the pass side has been milled.
Old 02-28-2014, 10:43 PM   #10
Jack E/NJ
Jack E/NJ's Avatar
flatjack9>>> I'd put it in a car a drive the H--- out of it. >>>
Ross-F1>>>Until there's a load on it, you're just wearing the rings out to run it.
Yup. You can come back after about 1-2K miles and tell us what the numbers are then.
Jack E/NJ
Old 02-28-2014, 11:25 PM   #11
alan
you actually wear the rings to seat them-don't you???
Old 03-01-2014, 06:16 AM   #12
JWL
It is normal for one bank to have slightly higher pressure when both heads have similar volumes. No, the compression is not too high.
I appreciate what Flatjack said and second the motion.
JWL is offline   Reply With Quote
Old 03-01-2014, 02:23 PM   #13
Pete Fl/Wi
Pete Fl/Wi's Avatar
This engine was built in 1989 and ran in a 48 coupe up untill it was swaped out for a CXXX crate engine in 1999. It looks to be the best candidate for my AV8. I am going to take Flatjack and JWL advice and run it hard.
Pete
Old 03-01-2014, 03:08 PM   #14
Lawson Cox
Lawson Cox's Avatar
Did you fabricate your jack stands/rollers? Neat.
Old 03-01-2014, 05:55 PM   #15
scooder
So what's gonna happen to the Edelbrock heads and Sharp 4 pot intake? You are putting them back on arnt you? If not stick um in a box and I'll look after them.
Martin.
scooder is offline   Reply With Quote
Old 03-01-2014, 06:17 PM   #16
Pete Fl/Wi
Pete Fl/Wi's Avatar
Lawson check out http://www.backyardbuddy.com/ I love them safe and easy to setup and move.
The heads are wall art. One had a crack that I think could be fixed by welding but for now I put them aside. I sold the intake to help cover the cost of buying the engine. I have enough problems running two carbs on my 40 panel.
Pete
Old 03-02-2014, 03:36 AM   #17
Mike B
Originally Posted by JWL View Post
It is normal for one bank to have slightly higher pressure when both heads have similar volumes. .
Why would that be?
Asking to learn.
Mike B is offline   Reply With Quote
Old 03-02-2014, 06:55 AM   #18
scooder
Pete, I did wonder why you took them off, makes sence.
Mike, the valves are at different angles either side of the engine, the eyebrow reliefs that the valves sit in on the deck surface are a slightly different shape and volume. This leads to different total combustion chamber volume, intern leading to different compression between each side.
Some heads account for this, having a left and right head. Basic part #6050 and #6049. One is left and one is right. But can't remember at the mo, which is which. These heads were ment to have slightly different chamber sizes to correct the compression ratio.
Hope that's clear.
Martin.
Old 03-02-2014, 08:53 AM   #19
JWL
Mike B.--- because the valve locations and associated height, block, and seat topography are different from bank to bank. In other words, the volume differs before the heads are installed.
Old 03-02-2014, 09:31 AM   #20
Talkwrench
Talkwrench's Avatar
Is that the same for ALL blocks ?
