Old 02-25-2014, 12:20 PM   #4
jkeesey
jkeesey's Avatar
Default Re: Gas leak from Zenith carb vent hole
The Viton tipped valves work better than standard depending on the manufacturer. Is the float valve you are using standard brass or a replacement? You "should" be able to get it apart to look.
jkeesey is offline   Reply With Quote
