Old 02-19-2014, 01:03 PM   #6
midgetracer
midgetracer's Avatar
Default Re: Car won't start. Help!
A stuck starter will not affect the charging system. If the generator quit, the voltage could be too low to run the car, so make sure you have at least 6 volts with a draw, such as the lights on..... Do the lights work, Horn????
midgetracer is offline   Reply With Quote
