Has anybody out there in Model A land converted a Model A 6v Generator 3 brush to 12 volts
Most, if not all, the vendors sell the parts to do so.
Do a search on the subject. Fellow FordBarn'er Mr. Purdy Swoft has done it to a Model-A or two that he owns. I think it basicly boils down to changing over to a 12 volt battery.
![]() Probably a little more to it then that, but I'm sure someone with more info should jump in and give you the correct procedure. ![]() Bob-A ![]() |
The generator really doesn't care about voltage. It'll work as is.
#7 | |
![]() Quote:
I prefer the positive ground twelve volt setup and it has worked great for me. This setup is really easier on the generator because it operates on less amps. If you want to run lots of accessories this may not work as well. I do use the 35 watt halogen bulbs but correct reflectors are necessary if you want the headlamps to focus. |
#8 | |
![]() Quote:
Bill, like the fellas said, the generator doesn't care about volts. It'll work as is. If the battery is changed from positive to negative ground, then it'll need to be re-polarized/flashed thats all. |
Just like Pat said, the generator doesn't know the difference. In other words, the generator charges in AMPS, amps charges the battery. This type conversion is really an easy UPGRADE. It works good for me and it doesn't show. I got my battery at Walmart so that I could pick the battery of choice, Both posts are on the same side with twelve volt batteries instead of being oiffset like the 6 volt batteries. I chose a battery with both posts on the right side with the ground post at the right rear.
Hey, thank you all for your very informative replies--I have changed the starter to 12v by swapping field coils with another starter and the horn by rewiring the field coils according to Les Andrews--they both work great but I wasn't sure about the genny--now I know.
Thanks and cheers Rosco |
