Old 01-31-2014, 09:09 PM   #1
[email protected]
Default Model A Back Cowl Mounting Screws
Are the rear hood mounting screws secured with machine nuts? The screws go at a slight angle and terminate in a hard to reach area between the firewall and gas tank.
Are the nuts accessed by hand in-between the firewall and gas tank, or do the screws grip with what's in-between then firewall and gas tank?
Synder's catalog shows the rear hood mounting screws sold as a set of two on page A-163. Nuts are not depicted, leading me to believe nuts are not used.
Any ideas? Please Help!
ssals@att.net is offline   Reply With Quote
Old 01-31-2014, 09:27 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Model A Back Cowl Mounting Screws
Yes, however the nuts are "cage nuts" meaning they have a small sheet metal strap around them to hold them while you install/remove the machine screw.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 01-31-2014, 11:33 PM   #3
Quigley1930
Quigley1930's Avatar
My cage broke and one nut escaped. With a young helper holding, I believe, a 12-24 nut up between the tank and firewall I could get the screw started and tightened.
Sewall Tyler
Quigley1930 is offline   Reply With Quote
Old 01-31-2014, 11:40 PM   #4
[email protected]
Thanks Brent. Any idea where to purchase the cage nuts? Steve
Old 02-01-2014, 05:41 PM   #5
[email protected]
Found cage nuts at Fastenal.
Old 02-01-2014, 11:20 PM   #6
Quigley1930
I believe you are going to have to remove the gas tank to install the cage nut. If the tank is out I would use Brattons PN 22392.
Sewall Tyler
